I have some left over coiled mill finish aluminum. It is .0385" thick and I have one piece around 4'x12' and another that is 8.5' x 12', maybe longer, maybe shorter. It is coiled and I don't have a lot of room to uncoil them and measure exactly. If anyone is interested I can try to get more accurate measurements by using the diameter and circumference to find the length. I also have two .063" sheets that are exactly 5' wide x 4'8" or so.
I'd rather not have to mess with cutting it to part out because as I said I don't have much room to uncoil it. The sheets are 5052 but I don't know about the coil. I can get some pics too if needed. This has been stuffed in the back of my garage since last year and I can barely even move the large piece. It has been protected from the elements but even so the surface of the aluminum is discolored a bit.
Any reasonable offer considered. Thanks
Lucas
