Welder wanted 92584 Zip code
Postby KenC » Wed Aug 25, 2010 9:45 pm
Hi All,
I'm looking for an expereinced welder with a portable set up that can come to my home and weld my trailer frame for me, I have the 2 x 2 steel for the frame and 3 X 3 steel for the tongue. I'll pay the going rate, I just want it done right by someone that has done fabrication work before. Any referals and recommendations for someone in the 92584 Zip code (Menifee CA) or surrounding areas would be greatly appreciated.
Thanks,
Ken
KenC
Images: 41
Postby Shadow Catcher » Thu Aug 26, 2010 5:44 am
If you have no luck on forum, you may want to check local pipe fitters union and or welding supply houses, they will generally know who is available locally and if they are any good. If you can find some one certified to weld in a G6 position (overhead at a 45 degree angle) they likely can weld anything :thumbsup:
Postby KenC » Thu Aug 26, 2010 10:29 pm
Thanks Shadow Catcher,
I'll continue my search. :D
KenC
Images: 41
Return to For Sale/Wanted
