Specs:
5' x 10' Cabin
14 1/2' from coupler to rear
Frame was custom built for trailer
Trailer weighs about 1100 lbs. dry
Tongue weight is about 100-110 lbs.
Has sealed beam marker lights and LED
tail/turn signal lights.
12v battery and Coleman propane stove are included mattress can be included for an additional $200
Tows great behind anything we've towed it with
Has 14" aluminum wheels, tires are real good and bearings were greased before our last trip.
Cabin is built with 1/4" birch ply inside and 1/4" oak ply outside with 3/4" framing and 3/4" foam insulation in the walls.
Roof has 1 1/2" insulation in it.
Floor is not insulated, your mattress takes care of that.
Cabinet face frames are pine for light weight, doors are pine frames with oak ply inserts.
Lots of cabinet space in the cabin and the galley!
We have had most everything in the trailer except the coolers and our coats when we traveled.
Has two double 12v swivel reading lights and one 12v ceiling light in the cabin. It also has a double 12v ceiling light mounted in the galley hatch.
This was all the electric we've ever had a need for. You could put 110v in it if you really needed it.
Cabin is built to hold a full queen size mattress.
Everything in the trailer is functional and there are no known leaks.
Tongue box will hold camp chairs and such, lots of room in it for extra stuff.
I'm a letting this go cheap because it is due to be refinished on the outside and it could use some exterior trim work of your liking. The fenders will need repainted because the Badlands took their toll on them this year.
The roof is sealed with fiberglass resin and painted with base clear automotive paint. The exterior walls need a light sanding and coating in the finish of your choice.
I don't have time this year to do the refinish and my storage garage is plugged up. I'd rather let it go for less $ than have it sit out all winter.
Trailer was built in 2005 and has approximately 20k problem free miles on it. It has preformed flawlessly every time it has been out.
I don't believe you will be disappointed with this trailer, it was very well built.
The trailer has never been titled (I'm in PA, 'nuff said) It can be titled here if you want to do the paperwork or title where you live, it's probably simpler.
Price is $4500 but I will entertain reasonable offers.
More pictures can be seen here
