Teardrop For Sale in Colorado - $2950 ~SOLD~
Postby Nathan » Thu Feb 19, 2009 4:37 pm
TEARDROP FOR SALE IN COLORADO - $2950
<img src='http://home.comcast.net/~coitnathan/SideView.jpg' >
Home-built modified Benroy 4x8 Teardrop Camper
This camper is "modified" because the standard galley bulkhead does not extend all the way to the deck. This makes the full 8 feet leg room available inside. This is great for taller people (I am 6'3").
Features -
Welded tublar steel frame with closed-off ends - no water can get in.
Triple support frame neck.
Three layer insulated deck, tar over 1/2 inch exterior plywood bottom.
Tie down hooks around frame edge.
0.040 aluminum skin fixed with trim.
Two hidden hinge doors with locks.
Hurricane hinge galley hatch with single locking latch handle.
Storage battery mounted at rear with attached charger.
Shore power exterior socket with internal outlet.
Porch lights, galley light, interior overhead light, (2) interior reading lights.
3/4 inch birch plywood sides, finished clear.
Insulated roof.
White oak hurricane hatch cross-pieces for ultimate strenght.
1/8 inch angle steel re-enforces to white oak cross-pieces in roof.
8 screw studs welded to angle steel for mount points on roof.
Non-electrical roof vent, but wire available for upgrade.
14 wheels with fenders
12v interior outlet, doubles as solar charging connector.
1 amp portable solar panel.
110v 75W converter.
RV style fixed AM/FM/CD stereo.
XM radio unit cradle.
Small internal catalytic heater.
3 inch x 6 ft foam pad - fits interior floor.
Weight 960#, tongue weight <100#, length overall 11 ft, width 4 ft.
Please contact Nathan at [email protected] for bunches of pictures and other details.
Nathan
Postby Marti Domyancic » Fri Feb 20, 2009 11:45 pm
Wow, this one seems to be loaded, Wish I knew someone that was looking for a good deal!! Good Luck
Marti Domyancic
Marti's Awnings
The lady with the shady business
www.trailerawning.blogspot.com
www.Martisawnings.com ( under construction)
Marti Domyancic
Return to For Sale/Wanted
