It is in good working condition.
It has the following built-in features:
15 amp 120 VAC circuit breaker
120 volt outlet
12 volt dc wiring circuits (FUSED) so you may run 12 volt circuits (of course).
6 amp DC output per the label on the converter.
Also, a line dedicated to connect to a 12 volt battery so the 12 volt dc circuits will work when 120 VAC is not available to run the converter.
A switch to turn the 12 volt converter on/off, and to switch to and from 120 VAC and battery operation.
Additional 120 volt wiring circuit so additional 120 volt AC receptacles can be added.
$25 + shipping
