Page 1 of 1
12 volt RV power converter **SOLD**
PostPosted: Sat Mar 07, 2009 2:48 am
by long live teardrops
This is a Progressive Dynamics 12 volt RV power converter. The power cord on this power converter is approximately 21 feet long. I removed the converter from my pop-up camper about a month ago when I stripped the camper down to the frame.
It is in good working condition.
It has the following built-in features:
15 amp 120 VAC circuit breaker
120 volt outlet
12 volt dc wiring circuits (FUSED) so you may run 12 volt circuits (of course).
6 amp DC output per the label on the converter.
Also, a line dedicated to connect to a 12 volt battery so the 12 volt dc circuits will work when 120 VAC is not available to run the converter.
A switch to turn the 12 volt converter on/off, and to switch to and from 120 VAC and battery operation.
Additional 120 volt wiring circuit so additional 120 volt AC receptacles can be added.
$25 + shipping :delivery:
PostPosted: Sat Mar 07, 2009 9:45 am
by Nitetimes
Check your PM's
