Wanted.... Dolly Wheel to fit this jack.... FOUND
Postby sid » Sun May 31, 2009 2:07 pm
I am looking for a Dolly Wheel and Clip to fit my 1947 Cub/Modernistic Teardrop. It looks to be about a 1 inch shaft.
I know there are a lot of ways I can put a wheel on here, but am really looking for an original type wheel.
Please PM me if you can help.
Thanks,
Sid
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby tinksdad » Sun May 31, 2009 5:43 pm
Is the shaft hollow?? A 3/4" socket and a ratchet removes the front wheel off a shopping cart in the middle of the night!! :MLAS Not that I'm recommending you do anything illegal!!! You could slide the threaded portion up inside and pin it temporarily until you find the right one.
tinksdad
Images: 155
Postby sid » Sun May 31, 2009 7:57 pm
Thanks for the idea, but I'm really looking for the correct wheel to keep it as original as possible.
It's not a rush job since I'm on teardrop time. The whole trailer has been disassembled so it's easy enough to move around.
It is a solid shaft. I know someone out there somewhere has one......
sid n side
sid
Images: 194
Postby 48Rob » Mon Jun 01, 2009 6:23 am
Hi Sid,
I don't have any extras, but here is a picture of an era correct wheel.
The wheel has a hollow tube that fits over the jack shaft.
The wheel/tube also has a thumb screw that projects into the groove on the jack shaft to hold it in place.
Rob
<img src="http://img.photobucket.com/albums/v284/1948rob/wheel4.jpg?t=1243855096">
48Rob
Postby sid » Mon Jun 01, 2009 6:53 am
That sure looks like what I need.... and yes, it does have the little groove on the shaft.
Thanks for posting the picture!
sid n side
sid
Images: 194
Caster
Postby danlott » Mon Jun 01, 2009 11:55 am
With a little work you could make this work. Would not be exact, but close.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_40252_40252
Hoplite Traveler Build thread
danlott
Images: 264
Postby bobhenry » Mon Jun 01, 2009 1:46 pm
A little closer and all steel ..............
http://www.towshop.com/store/pc/viewPrd.asp?idproduct=575&idcategory=80
With a 2" I.D. you would have to sleve it but it's looks right.
Bob
Postby sid » Fri Jun 26, 2009 3:15 pm
Bump......
Still looking for that wheel....
sid n side
sid
Images: 194
Postby Barry and Darby H. » Fri Jun 26, 2009 6:53 pm
Hi Sid,
I don't know what year these are but I might be talked out of one of them if I knew it was going to a loving home. One has a thumb screw to tighten it to the shaft and the other doesn't. That's about all I can tell you about them.
[img]http://www.tnttt.com/gallery/image.php?image_id=51822][/img]
Let me know if one of these is what your after.
Barry
Barry and Darby H.
Images: 29
Postby sid » Sun Jun 28, 2009 10:12 am
We have a wheel on the way thanks to Barry Haskell.... the New England Chapter Director. :applause: :applause:
Many thanks,
Mark and Pat
sid n side
sid
Images: 194
Return to For Sale/Wanted
