FS: Cargo conversion
Postby mwatters » Sat Jun 13, 2009 9:38 pm
This was converted from an 80's HiPoint bike hauler trailer.  4x4 door in rear.  Bought and converted a few years ago with grand plans - then came the twins.  Plans went out the window.  I've finally let go of the plans - so it's time to let go of the trailer.  Currently set up to accommodate one bike.  Two fold down bunks along the sides.  Front has wheel chock, 110 fridge and drawer unit as well as two storage shelves/counter.  Front also has a nook intended to house a porta potty.  The trailer was originally built to be a cargo trailer and haul bikes so it's fairly sturdy and robust.  Body is molded fiberglass.  The body is supported by a steel interior frame, so it's not going anywhere.  I added the three windows and the powered ceiling vent.  The side door has a standard RV lock which was replaced 3 years ago.  Rear door can be locked from either the inside or out and folds down into a ramp.  Exterior was repainted 2 years ago.  It has two independent electrical systems.  A 110 system runs the fridge and goes to two normal outlets.  The 12V system was rigged up to run from a jumpstarter (not included) for simplicity.  If I were to do it again though, I'd drop that idea or just pick up the converter so the whole thing could run off of 110.  My recollection is that the 12V system should be gone through.   The interior of the trailer was sheathed in real wood paneling, stained and polyurethaned for that nice woody environment.  More pics available.
Interior is about 6.5' wide by 10' long.  Interior height is just under 5'.  Exterior dimensions are around 7x13.  Exterior height is about 6.5' so it should easily fit into any standard garage.  Distance from front of chock to rear is 9.5', minimum distance between bunks when up is 3'9".  Includes interior (removable) table AND table which attaches to exterior of trailer.  There's also an awning rail already there - but no awning included.
Asking price is $2500.  I'm open to offers.  Just in case anybody's interested in a package deal, I'm also selling a pair of '80 Honda CB650's - one running, one not.
Mike
Watters
mwatters
Postby mwatters » Sat Jun 13, 2009 9:56 pm
Here's what it looks like - more photos in my album (mini1-mini8).
Mike
Watters
mwatters
Postby mwatters » Sun Jun 14, 2009 7:50 pm
Sorry I left this bit out: I'm located in Valparaiso Indiana (near Chicago).
mkw
Mike
Watters
mwatters
Postby mwatters » Sun Aug 09, 2009 6:39 pm
Price Reduced: $2000
Mike
Watters
mwatters
Hello
Postby Jeeper92 » Sat Aug 15, 2009 3:36 pm
Is it dry????????????
Jeeper92
Re: Hello
Postby mwatters » Sat Aug 15, 2009 7:45 pm
Jeeper92 wrote:Is it dry????????????
Well, I haven't been drinking in it - so I suppose you could say it's a dry trailer. :lol:
More to the point - it doesn't leak either. The 12V "fantastic vent" hasn't been a problem. The doors are the other vulnerable point. Between the weather stripping and the gutters they haven't been a problem either.
The only real problem is that I started this project with 2 fewer kids than I have now. That's what I get for planning ahead... The other problem is that I've got three trailers, so stuff has gotta go.
Mike
Watters
mwatters
Postby mwatters » Sat Aug 15, 2009 7:55 pm
More on leaking: That's one of the advantages of the fiberglass. The body is molded fiberglass with glassed-in foam insulation. Body was molded in three pieces - so there's two seams. The seams were caulked with acrylic and painted over (topside boat paint).
The fold-down bunks have standard RV dinnette cushions on them. 6' on the door side (although the cushion is longer - cut down or add extended support). Bunk on the road-side is 6'8".
Mike
Watters
mwatters
hello
Postby Jeeper92 » Thu Aug 27, 2009 10:43 pm
Please let me know if you stil have it come spring thanks
Jeeper92
Postby godskid » Fri Aug 28, 2009 2:04 pm
Any idea of the weight of this cutie? Too big for my MINI cooper to pull, I think, but my husband might be interested in a small trailer for himself. I'll ask.
godskid
Images: 10
Postby mwatters » Fri Aug 28, 2009 11:03 pm
I haven't gone in to weigh it so I don't know. I would GUESS it was something around 1500lbs. The original trailer would have been fairly beefy since it was built to haul bikes. The steel superstructure is gonna add up too. Fiberglass upper won't be all that much - and there wasn't that much weight added to the interior (had to leave room for the bike).
Mike
Watters
mwatters
Return to For Sale/Wanted
