This was converted from an 80's HiPoint bike hauler trailer. 4x4 door in rear. Currently set up to accommodate one bike. Two fold down bunks along the sides. Front has wheel chock, 110 fridge and drawer unit as well as two storage shelves/counter. Front also has an area intended to house a porta potty. The trailer was originally built to be a cargo trailer and haul bikes so it's fairly sturdy and robust. Body is molded fiberglass which keeps it very dry inside – no leaks. The body is supported by a steel interior frame, so it's not going anywhere. I added the bunks, front storage, three windows and the powered ceiling vent. The side door has a standard RV lock which was replaced 3 years ago. Rear door can be locked from both inside and out and folds down into a ramp. Exterior was repainted 2 years ago. It has two independent electrical systems. A 110 system runs the fridge and goes to two normal outlets. The 12V system was rigged up to run from a jumpstarter (not included) for simplicity. My recollection is that one of the 12V interior lights wasn't working (probably need to redo the wires). The interior of the trailer was sheathed in real wood paneling, stained and polyurethaned for that nice woody environment.
Interior is about 6.5' wide by 10' long. Interior height is just under 5'. Exterior dimensions are around 7x13. Exterior height is about 6.5' so it should easily fit into any standard garage. Distance from front of chock to rear is 9.5', minimum distance between bunks when up is 3'9". Includes interior (removable) table AND table which attaches to exterior of trailer. There's also an awning rail already there - but no awning included.
Asking price is $2500. I'm open to offers. I'm located in Valparaiso Indiana.
Additional photos are in my gallery
