SOLD For Sale- WFCO 8712P converter ($50) SOLD
I bought this converter for a trailer rebuild that never happened and it has just been sitting on the shelf for about a year. Time to bite the bullet and sell it to someone that can use it. The converter new is currently $93.50 + shipping (bestconverter.com). I'll sell the converter for $50 (+$10 flat shipping).
Here are the specs for the converter (I purchased from bestconverter.com):
Description
Automatic three-stage charging provides superior 12-volt system performance while maintaining the ideal charge and maintenance of your battery.
WF-8712 model converters provides 12Adc output, and a highly reliable nominal 13.6 Vdc with or without a battery and no extra filtering is required.
WFCOs three-stage battery charging results in longer battery life, and is totally automatic. Nominal voltage output modes are a 13.2 Vdc float mode, 13.6 Vdc absorption charge mode, and a 14.4 Vdc bulk charge mode. Short circuit and reverse polarity protections provide you with further reliability and peace of mind.
Every model is FCC Class B compliant which means the converters do not cause interference with televisions, radios, and other signals. The 8700 Series also brings you the convenience of built-in AC and DC distribution. 30 Amp main AC breaker and total of up to three 20-Amp branch AC circuits can be installed. DC circuits include LED lights which illuminate to indicate open circuits.
Specifications:
UL and cUL listed. FCC Class B
Warranty period: 2 year warranty
Output Power: 12 Amps DC Output
Input: 105-130 VAC, 60 Hz, 3.0 Amps (163 Watt)
Output:
- Nominal (Absorbtion Mode) 13.6 VDC (includes charging and load);
- Boost (Bulk Mode)14.4 VDC;
- Trickle (Float Mode) 13.2 VDC (after 48hrs)
Dimensions: 12 wide; 7.25 high; 4.5 deep
Cut-out: 10.5" wide; 6" high; 4" deep
Weight: 4.75 lbs.
Send me a message if you are interested. Thanks!
