Low edge Hauler Motorcycle trailer
Postby khiers1960 » Sun Aug 04, 2013 6:35 am
JUST REDUCED SOLD BOTH BIKES NO LONGER NEEDED.
EDGE LOW HAULER MOTORCYCLE TRAILER
The Low Hauler Edge is a premium value trailer with all of the amenities necessary to haul your bikes in style. The smooth exterior, polished aluminum trim items and side panels, the fully finished interior and aluminum wheels make this a trailer you will be proud to show your friends and competitors.
Features:
Smooth screwless exterior - Great for graphics
White vinyl interior walls and ceiling - Clean and bright looks
Polished aluminum front cap and corners - Distinctive appearance helps get you noticed
Aluminum wheels - Classy, upscale look
Polished aluminum lower side panels
L.E.D. exterior lighting - Safer and longer lasting
D-ring floor and wall tie downs - Prevents bikes from moving
Removable wheel chocks - Increases cargo flexibility
Drop-down stabilizer jack - Helps stabilize trailer during loading
Rubber ride suspension - Premium ride quality
Radial tires - Improves ride
Has always been kept under covered shed and parked on boards to keep tires off the ground.
3250.00 or BO 864-378-4583 Will not respond to a text message. Cash or cashier check only.
khiers1960
Return to For Sale/Wanted
