Alright, so the time has come to part ways with my teardrop project. My needs have changed and a small trailer just won't do what I need. Everything is brand new. You will get the following:
HF 1720# trailer modified to 4x10. The trailer has had all joints both bolted and welded together as well as putting sister plates on the trailer halves to allow for the long leaf springs. I extended the frame 2' to the rear as well as doing a tongue extension to accommodate the 2.75 cu/ft tongue box that comes with it. The rear extension isnt perfectly level, so it will need to be reworked a little. All it will take is grinding away some welds and rewelding.There is also a jack welded onto the tongue extension that is equipped with a 2" hitch. The trailer is equipped with 2" lift Rough Country Jeep Cherokee leaf springs on a 3500# axle fitted with 10.5" electric brakes and 15" wheels and goodyear tires. The floor is made of 3/4" birch ply built to 5x10, and the trailer comes with 3 sheets of 1/2" and 1/4" birch ply for the walls. You also get a 21 gallon water tank, instant hot water heater, water pump, and ceiling vent with fan. You get all the interior and exterior lighting you will need; one 16' spool of flexible led strip with dimmers you can use for lighting anywhere, 10 round switches with blue led indicators, hybrid tail lights, and led marker lights. It will also come with four 100' spools of wire for setting up the electrical. I sanded the whole trailer frame and repainted it hammer finish silver. You will also get a 2 burner camp stove with built in broiler. I have just about $3000 in receipts for everything that you will get for $1100. I didn't take any pics of the 3 sheets of 1/2" and 1/4" birch ply because it seemed self explanatory
Was asking $2000, then $1750, then $1500, and NOW $1100!!!!
I am located in Ellensburg Washington.
If you have any questions, just let me know.
Thanks!
Peter
