2011 Home Build "Blue Yonder" For Sale - SOLD
Postby Loader » Fri Nov 07, 2014 7:50 am
Time has come for us to sell the Blue Yonder, as we need to get something a little bigger so we can bring our granddaughter and new grandbaby (due in Apr 2015) out with us. Now a bit about the trailer:
Located in Ft Worth Texas, construction began in Feb 2011 and its first outing was to LCG in Oct 2011. The chassis is a custom made by a professional fabricator here in Ft Worth. It is a 5x10 with a 3500lb Acculube axel with 15” tires and a 2-inch coupler (documentation provided). It is equipped with easy-lube hubs.
The design of the Blue Yonder was inspired by a Scadabout design. It is not intended to be a Scadabout clone, as I said the Scad was the inspiration. There is an 8-inch queen size memory foam mattress inside, plenty comfortable. There is a lot of interior storage with headboard and over foot cabinets. There is a 110 and 12VDC outlet in the cabin, along with a set of aircraft style overhead lights. A Fantastic Fan, multi-speed and reversible is there for the days you need a little breeze. For those really hot days or cold nights, there is a PetCool AC/Heat Pump installed. The trailer is register as a Texas Utility trailer and will come with a Certificate of Origin as compared to a Texas RV Title.
In the galley, first thing most notice is the half hatch design and large storage area under the counter top, assessable without needing to open the hatch. The hatch is equipped with gas struts. There is a built in wine bottle rack. The coffee pot and microwave are included. The “nose art” in the galley was hand-painted by my wife; it is a copy of actual WWII art. In the galley is the power panel that connects to your campground shore power using the connection point on the driver side of the trailer. There is no battery installed, but the power panel can support one if the new owner wants to install one.
The exterior is covered with painted aluminum and has little (if any) signs of wear as the trailer has always been stored inside. The aircraft decals on the sides should be able to be removed if desired. The two entry doors have stay open latches so you can show off the interior or just get the fresh air when parked. Each door has jealously style windows and lockable door latches. The two doors are keyed the same.
I understand that this is a very customized trailer, with all the US Air Force decorations. However, the curtains and door pulls can be replaced easily if desired.
I will admit I have never weighed the trailer as I tow with an F-150, but my guess would be somewhere between 1200-1500 pounds. To aid with hand moving, a trailer dolly is included as is the spare tire. I normally toss it in the bed of the truck, but would think it could be mounted to the trailer frame.
Build pictures and discussion throughout the build can be found in my build thread located here: http://www.tnttt.com/viewtopic.php?f=50&t=42611
I’ll be glad to answer any questions you may have.
Thanks for looking,
Earl
Earl & Kerry
"Loader"
Loader
Images: 245
Re: 2011 Home Build "Blue Yonder" For Sale - $4000
Postby steve cowan » Sun Nov 09, 2014 2:15 pm
Nice trailer!You did a great job on it.
:FNP
steve
steve cowan
Images: 207
Postby Loader » Mon Nov 10, 2014 2:48 pm
steve cowan wrote:Nice trailer!You did a great job on it.
:FNP
steve
Thanks Steve, I appreciate the comment!
Earl
Earl & Kerry
"Loader"
Loader
Images: 245
Postby aggie79 » Wed Nov 12, 2014 10:46 am
**** BUMP ****
If are looking to purchase a teardrop, this is a great one to get.
I've seen it up close several times. It's a quality teardrop built by a quality person.
Postby tonyj » Fri Nov 14, 2014 1:59 am
I'll add to Tom's comment--the quality of this trailer is second only to the quality of its builder and owners.
If you are considering a purchase, look at this one first!
tony
tonyj
Images: 160
Re: 2011 Home Build "Blue Yonder" For Sale - SOLD
Postby Loader » Sat Nov 22, 2014 1:19 pm
Thanks for the kind words Tony and Tom.
As of this morning, the Blue Yonder is sold.
Earl & Kerry
"Loader"
Loader
Images: 245
Return to For Sale/Wanted
