Wanted: Roof Sealant Tape?
Postby Alfred » Sat Aug 01, 2015 12:11 pm
Hi All,
I read somewhere about some roof sealant tape, thought it might not be a bad idea to put some on the seams of the Weekender roof. Anybody have any for sale before I order a new roll?
Thanks,
AL in Asheville :thumbsup:
Alfred
Images: 368
Re: Wanted: Roof Sealant Tape?
Postby dales133 » Sat Aug 01, 2015 12:14 pm
Got a link to it Al?
Ive used something similar on buildings thats verry sticky self adhesive with a foil face.
Not sure if thats what you mean.
dales133
Postby Alfred » Sat Aug 01, 2015 12:39 pm
dales133 wrote:Got a link to it Al?
No, I'll have to look for it, been awhile. As I recall this was very sticky stuff, but was made just for RV's. Someone on the forum had described it. I'll have to do some more research.
Thanks, AL
Alfred
Images: 368
Postby GuitarPhotog » Sat Aug 01, 2015 1:32 pm
What you want is this Butyl Putty Tape.
http://www.vintagetrailersupply.com/But ... ts-419.htm
I used when I patched a hole in the roof of my standy and it has held up perfectly. Not easy to apply on a hot day or hot surface. Keep it in the fridge before applying.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Treeview » Sat Aug 01, 2015 1:35 pm
You might be looking for butyl tape.
http://www.pbase.com/mainecruising/butyl_tape
One of many sources. I have no clue who the manufacturer is. Like anything, the quality of the product can be quite different no matter what generic name is on the packaging.
Treeview
Images: 30
Postby MtnDon » Sat Aug 01, 2015 1:46 pm
Eternabond is the stuff to use if a seam is already assembled. Butyl tape is great for use when assembling a roof, wall, etc. It sticks to just about anything.
MtnDon
Images: 24
Postby Alfred » Sat Aug 01, 2015 4:01 pm
Hi All,
This is for the camper I built 4-5 years ago now, weekender shaped, so it has seams where the flat pieces meet. I used some sort of putty at the time, and I painted with the epoxy paint, but looking for the type of roof tape that would go on after-the-fact, just to make certain we're good. I've actually never had it in much water. I store it in the garage, and even when I take it out, if it rains, I put it under the EZ-up Canopy.
AL
Alfred
Images: 368
Postby MtnDon » Sat Aug 01, 2015 4:54 pm
AL, the Eternabond will do the job. We had an old Class C years ago that had leaks around the corners of the cab over section. Wrapping the corners with Eternabond eliminated the leaks. I painted over the white with almond paint that matched the RV color very well.
MtnDon
Images: 24
Return to For Sale/Wanted
