The trailer was special ordered and delivered in December 2017 through Colorado Trailers in Castle Rock, CO. I purchased it brand new and have the title in hand. The trailer weight comes in around 1,400 lbs from the factory and it is rated to carry 1,590 lbs of cargo for a GVW of 2,990 lbs. It towed well behind my 4.0L Tacoma. The base is a 6x12 cargo trailer with the following options:
- Offroad package (includes 32" mud terrain tires)
- 3500 lb torsion axle with electric brakes
- 6'6" interior height
- insulated walls, ceiling, and floors
- blackout package
- stabilizer jacks at all 4 corners
- white aluminum skins on the walls
- rubber coin mat floor
- Pepsi Blue/black two tone exterior
- (2) 15" x 24" windows on the sides of the trailer
- 36" RV door on the back with locks, a screen door, and frosted privacy glass
- aluminum ladder on driver's side
- matching spare tire
- swiveling tongue jack with wheel
- removable coupler
In addition to the options coming from the factory, I have added the following:
- single row LED light bars on the roof to illuminate each of the trailer sides
- Maxair multi-speed vent fan
- 14 x 30 skylight above the bed
- 2.2 cu ft locking metal tongue box
- ARB 8' awning on passenger side
- reinforced roof structure that is drilled and tapped to accept 2, 100W Renogy solar panels
I won't get into all of the details in this ad, but the build thread can be found here: https://www.expeditionportal.com/forum/ ... er.189390/
Trailer is located Westminster, CO for showing. It will come with all documentation that I have as well as all parts for re-assembly. I have over $9,000 into it as it sits and am asking $8,000.
I am also selling a small pile of parts that could assist in finishing out the trailer. I'll be selling separately or will provide a good deal if someone wants to buy any or all of this at the same time along with the trailer.
Lock n Roll hitch, 4" drop, 30" extension
Blue Sea 12 circuit fuse block
Blue Sea 100A breaker
