Tile in a Teardrop?
Tile in a Teardrop?
Postby sabrown82 » Sun Jun 02, 2013 10:02 pm
Has anyone ever put tile in a teardrop? Does it hold up? I'm wondering if the vibration of travel would result in cracking....or it just all coming down. I would like to use tile for a backsplash around the sink.
Does anyone have any cool alternatives for a backsplash?
sabrown82
Re: Tile in a Teardrop?
Postby celticquetzel » Mon Jun 03, 2013 2:15 am
Hi, i just posted a response elsewhere on using polymer clay. Under vintage decorating. I'll link it tomorrow. (My kindle is limited).
celticquetzel
Postby GerryS » Mon Jun 03, 2013 5:23 am
I'd worry about weight....tile is heavy! I'd see if anyone has made a silicone based grout too. I would think all the movement would cause lots of cracks....
Personally, I'd stick to vinyl. Not as pretty, but it's indestructible, light, and easy to work with...
GerryS
Postby sabrown82 » Mon Jun 03, 2013 5:54 am
Celtic- I saw your post. Thanks for the idea. It sounds interesting and I'd be curious to see how it comes out, however; I don't think I'm the type of person who could sit around making clay tiles. :)
Gerry- I'm not so much worried about weight as this will likely be towed with an F-150 and the teardrop sits on an old self-contained camper frame. The frame was torn down and modified for this build. It's rugged and sturdy. I'm more curious as to whether the effect of travel will be a broken mess on my wall.
sabrown82
Postby les45 » Mon Jun 03, 2013 6:37 am
Here is a thread on this subject from about a year ago that may give you some good info:
viewtopic.php?f=21&t=51139&p=947616&hilit=tile#p947616
les45
Images: 605
Postby sabrown82 » Mon Jun 03, 2013 6:08 pm
Thanks les45! I was doing a search through the forums and didn't come up with that thread! That's exactly what I needed to know!
sabrown82
Postby Lgboro » Mon Jun 03, 2013 8:28 pm
I think if you install with an epoxy grout you would be ok. I plan on doing a few mosaic insets in my next build but won't start the build for a few more months. You might email some of the companies and get the correct info.
Lgboro
Images: 53
Postby planovet » Tue Jun 04, 2013 4:49 pm
I put 2x2 stone tiles on my galley counter.
Instead of grout, I used a colored and sanded caulk. It was a pain to use and dried rather quickly but my thinking is that it would be much less susceptible to cracking.
It's been 4 years now and not a single crack. It's very durable and I can set hot pans on it with no problems.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Junkboy999 » Fri Jun 07, 2013 11:01 pm
I believe this is Tile in Bubbles A few pictures down in this post.
viewtopic.php?f=50&t=54968&start=45#p1016770
Junkboy999
Images: 52
