Making a hot wire cutter
Postby Kody » Mon Oct 28, 2013 7:41 am
I am now ready to cut the foam down to be level with the timber frame. Once this is done, I can then glue on the last of the plywood to form the side wall. I don't know what gauge or diameter wire to use for melting thru the foam. I can buy some hard drawn stainless steel in many diameters. The stainless steel wire is very hard and springy, it actually makes beautiful tension springs. Can you guys recommend a diameter to use please? The length of the cutter is 28 inches and I will be using either a 12 volt battery or a 4 amp battery charger, whichever one works the best.
:thinking:
Kody
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Re: Making a hot wire cutter
Postby Dale M. » Mon Oct 28, 2013 8:12 am
Actually nichrome (nickel-chromium) is better choice for hot element.... Gauge?, maybe something around 20 gauge... Voltage should be low (12 volts?) current what ever it takes...
http://www.omega.com/pptst/ni60.html
Dale
Dale M.
Images: 18
Postby desertmoose » Mon Oct 28, 2013 8:45 am
When I cut out my pontoons, I used .030 dia wire from my MIG welder. (Copper plated steel)
Worked great with a 12V battery charger for the power supply.
Length was around 40" or so, but I don't think it's that critical. Shorter wire will be hotter and cut quicker. mine was pretty slow.
Sam
desertmoose
Images: 98
Postby GuitarPhotog » Mon Oct 28, 2013 10:15 am
Here's a site about hot wire foam cutters. http://hotwirefoamcutterinfo.com/Introduction.html
They explain the relationship between temperature, wire gauge, and current.
I powered one with an AC adapter plugged into a lamp dimmer, and another with three 1.5V D-cell batteries (high current capacity rechargables).
<Chas>
:beer:
GuitarPhotog
Images: 55
