Solar Tweak Finished
Postby hwitten » Tue Dec 03, 2013 1:42 am
I now have 70 watts on the roof. Hopefully that will do me as my usage is actually quite minimal, primarily the Engel fridge that lives in back of TV.
I found some wide tape that actually matches quite closely. I'm going to try it as it does allow for a bit of hiding of wiring. The downside of a store-bought vs built-ur-own, much more exposed wiring, etc.
First trip will tell if I will try and leave it on. Tape is only for looks but it might serve to protect a bit too as a bonus.
I just hope all the wiring and connections are good. Will have to wait until a day in the sun I guess.
Wiring in the raw.
Wiring covered for perhaps a bit better look.
hwitten
Re: Solar Tweak Finished
Postby Vedette » Tue Dec 03, 2013 2:41 am
Good Luck with that Heinz.
Just don't drive too fast! :twisted:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby PKCSPT » Tue Dec 03, 2013 3:03 am
I will be interested to see how this works. I am thinking of adding solar to mine next year and am thinking I want to do as you did.
121172 116946 159644
PKCSPT
Images: 61
Postby Esteban » Tue Dec 03, 2013 6:08 pm
Heinz, I'll be interested in your experience with yours. :thinking:
Flexible panels would seem to free us from needing enough flat roof area to mount rigid solar panels
Grape Solar has flexible solar panels that are as compact as their aluminum framed ones with the same output. They are tempting me. They have them with 15, 30, 50 and 100 watt capacities. Here is a pdf of the 100 watt one PhotoFlex-100W Lowes and Home Depot sell them.
Steve - SLO, CA
Esteban
Images: 15
Postby hwitten » Tue Dec 03, 2013 6:24 pm
Thanks Steve.
That sure looks interesting. Assuming it can stand being rolled up for storage after each use it will be an excellent candidate to throw on TV roof, etc.
hwitten
Postby Esteban » Tue Dec 03, 2013 8:21 pm
hwitten wrote:Thanks Steve.
Recently I called Grape Solar about mounting one on top with 3M tape like Shaddow Catcher has done with one of his panels. I was told many RVers and boaters do it. Or it can be rolled up for storage. You might give them a call with your questions during business hours. They answer the phone (no voice mail he!!) and the person I talked with was friendly and very helpful. He knew about teardrop trailers too.
Steve - SLO, CA
Esteban
Images: 15
Postby Shadow Catcher » Tue Dec 03, 2013 9:29 pm
If you can find them, Unisolar made flex panels, I have one 145W, the only problem is that it is 18' long, it is my roll it out in the sun on an extension cord panel. I found mine on ebay for $65. There are other thin film manufacturers but most of the prices I see are inflated.
Postby Esteban » Tue Dec 03, 2013 10:36 pm
Bruce posted a link elsewhere Mounting Solar Panel on curved roof that led me to find a 135 watt flexible solar panel for $275.00 that is approx. 21" x 58". ebay.com/Semi-Flexible-135-Watt-Solar-Panel-High-Efficiency-Sunpower They can be bent up to 30% which makes mounting one on a curved surface/roof/galley hatch easier to do.
Steve - SLO, CA
Esteban
Images: 15
Postby Esteban » Wed Dec 04, 2013 3:43 pm
Getting back to Heinz, how is your solar power system working for you?
Steve - SLO, CA
Esteban
Images: 15
Postby hwitten » Wed Dec 04, 2013 4:02 pm
Too early to answer if satisfactory success :)
Installation went good and relatively easy. Just had to make sure roof was clean. I used some painters masking tape to outline so that I'd have a better chance of being straight as once it's on.... it's on. Used a rolling pin to apply even pressure. Had done one side earlier as the manufacturer "forgot" that I wanted 2 panels. Made me a bit braver to try this latest tweak.
The PowerFilms are not cheap but are "supposed" to be more efficient in less than ideal conditions. Solar is a bit of a black box, really hard to test. I'll report on it after next trip. Maybe earlier if I get restless and yank it out on a nice day.
hwitten
Postby Esteban » Wed Dec 04, 2013 5:01 pm
Thanks Heinz for sharing your solar set up.
I'm very interested to hear from you, and others, with solar collectors who also use a fridge/freezer.
I wonder how much power fridge/freezers use in real world circumstances.
I also wonder how much solar power is needed to provide sufficient power to charge a battery to run a fridge, a Fantastic Fan and LED lights.
I had estimated maybe 20-30 amp hours per day would be used knowing it will vary with time of year, weather, location, devices, and individuals.
Steve - SLO, CA
Esteban
Images: 15
Postby hwitten » Wed Dec 04, 2013 5:25 pm
I did some measurements in actual use while I was trying to figure out my setup. The Fantastic Fan has highest draw. The Engel Fridge about 2 amps but not on all the time. I also planned on 12 Volt TV/DVD for 3-4 hours per day. My goal is to be able to "live" self-contained for 3-4 days at a time. By then a shower will be needed so we'll probably have power for a night :)
hwitten
Postby Tucguy » Wed Dec 04, 2013 5:39 pm
I can see this wiring harness under the upper skin in a new build or maybe in a hidden conduit installed at the build time for add on equipment such as your solar panels, cameras, lights, any additional wiring needs. Maybe we can come up with some standard design that could be put under the outer skin anywhere on the tear to allow later additions such as found on our automobiles for accessories like driving lamps, trailers lights, raised stop lamps, etc. Little Guy has wiring installed in their trailers that do not come with an electrical system for just such an addition. Love the flexible look.
Tucguy
Images: 53
