Holding a vertical door open - SOLVED
Postby eggsalad » Sun Dec 22, 2013 1:10 pm
I bet the title doesn't even make sense. It's hard to explain. I have a vertical door (as opposed to a horizontal hatch) at the back of my camper. It swings on a piano hinge. if I let it, it will open to 180 degrees. But that would stress the mounting, and there's a whole host of other reasons I don't want my door to open that wide. I'd like the door to open to 90 or 100 degrees and then lock there.
I've considered a gas strut, but honestly, I can't wrap my tiny brain about the geometry of the mounting points, and I think a gas spring might be TOO strong for this application.
Another idea is something called a "lid stay". It's something like you would see on a foot locker or a step ladder, to hold either one in the open position. I'm not convinced this is the best idea either.
What have some of you folks used to keep a door open, but not TOO open?
Thanks,
eggsalad
eggsalad
Re: Holding a vertical door open
Postby tony.latham » Sun Dec 22, 2013 2:13 pm
I used two of these. Stainless steel, nylon bearings and $10 a pop:
http://www.rcpw.com/truck-accessories/t ... DP100.html
They work well for my hatch. Dunno if they will do what you're trying to do.
Postby eggsalad » Sun Dec 22, 2013 2:16 pm
That may work! Thanks for the link!
eggsalad
Postby working on it » Sun Dec 22, 2013 2:18 pm
eggsalad wrote:... I have a vertical door (as opposed to a horizontal hatch) at the back of my camper.
I looked at your build thread and saw this:
I would attach a stay at the top, like this:
door stay.jpg (18.78 KiB) Viewed 794 times
I forgot where I found this photo, but I've made my own stays before, much like it. Or, you could reverse (turn it upside down, mount on the right) the mounting of your door, to open to the curbside, then you could mount a "cushioned" stop, or mechanical "trailer door" door clip to keep it from overtravel. And, that would enable a larger free space at the rear when opened.
173193172890148599
working on it
Images: 457
Postby eggsalad » Sun Dec 22, 2013 2:49 pm
working on it wrote: I would attach a stay at the top, like this:
I bet you found that photo here:
http://realcarriagedoors.com/hardware-i ... neous#jump
Neat idea. Obviously that one is way oversize, but I might be able to make one like that.
eggsalad
Postby skypirate » Sun Dec 22, 2013 8:13 pm
I use 2 closely wound coil springs for props on my galley hatch. I don't have a photo so use your imagination. ... These are extension springs, like old fashioned screen door springs. Mine are 7 inches long. I attached one to each side of the hatch just as you would position a stick as a prop. The coils are wound so closely that the spring is not compressible and is therefore rigid. Use a screw & washer to attach the ring on each end in position. (I added a couple of bushings too). Now the cool part, when you want to lower the hatch (or door) you simple push on the spring and it will "break" in half allowing the door to close. Be sure to keep one hand on the hatch otherwise it will just fall out of control. When you lift the door open again the springs will return to straight and become rigid props once more.
Just as effective as gas struts but only cost $4.00 at Home Depot. Good luck.
skypirate
Postby citylights » Sun Dec 22, 2013 9:49 pm
tony.latham wrote:I used two of these. Stainless steel, nylon bearings and $10 a pop:
I like it! The only concern I have is for wind. It says to unlock, extend slightly to release, then let down. Can the wind unlatch it and let it down accidentally? How do you deal with that?
citylights
Postby tony.latham » Sun Dec 22, 2013 11:22 pm
Yes, the wind can do that. I had the same system on my Hunter tear and it happened at least once. Here's the solution: when open, there's a hole that lines up and you can slip a 1/4" pin through them and lock em in place. There's at least two lengths made.
Postby citylights » Mon Dec 23, 2013 8:17 pm
tony.latham wrote:Yes, the wind can do that. I had the same system on my Hunter tear and it happened at least once. Here's the solution: when open, there's a hole that lines up and you can slip a 1/4" pin through them and lock em in place. There's at least two lengths made.
Sweet. Done deal, ordered them. Thanks!
citylights
Re: Holding a vertical door open - SOLVED
Postby eggsalad » Sun Jan 19, 2014 7:28 pm
The person called "working on it" gave me the idea. Of course, the ones shown in that post were for garage doors, way too big for my TTT. So I built one just like it, only scaled down.
Just some junk bits hanging around the shop, and about a dollar's worth of hardware. The wing bolt acts as a set screw, so the door can be "locked" in any position.
thanks for the idea, "working on it"!
eggsalad
Postby bentrotor » Sun Jan 19, 2014 7:59 pm
Why not just use a spring loaded door closure just like on an exterior storm door. Not only will it close your door automatically, you can prop it open to any angle you would like. You can get one at any hardware store.
bentrotor
Postby eggsalad » Sun Jan 19, 2014 8:11 pm
bentrotor wrote:Why not just use a spring loaded door closure just like on an exterior storm door. Not only will it close your door automatically, you can prop it open to any angle you would like. You can get one at any hardware store.
Why not, indeed? Fact is, there are a whole bunch of good, and not horribly expensive solutions. I just like making things myself.
eggsalad
