Well without the hub it's kinda difficult to explain but the generator/motor is mounted on the bottom a chain will run from the motor to the turbine hub. There will be a swivel mounted on the bottom. Once I have it balanced I will know where. The motor I used is a 2500 rpms at 24 volts at around 8amps. I'm not sure on the amps.
The motor needs to spin extremely fast for this to work close to 1500-2000 rpms at those speeds it will have around 15 volts and around I think 150-200 wats of power. To make it spin this fast we are using a 1-8 gear. That is a 6" 80 tooth gear attached to the prop and a .75" 10 tooth gear attached to the motor.
The motor came out of a small electric scooter it had the gear the chain and the motor all right there. Craigslist score 30$ for 2 scooters. The blades are PVC pipe the rule for making pipe blades is 1-5 ratio so for every 5" long you need 1" in diameter. I used a 6" PVC and the blades are about 30" long. You cut the pvc into 4ths and just cut an angle on one side. This will give you 4 blades and most turbines use only 3 so you have an extra.o
http://www.mdpub.com/Wind_Turbine/Here is the website my brother in law found. I used his as a base model and he also has a control box instructions too. Oh and solar panels.
