by doug hodder » Sun Dec 15, 2013 10:41 pm
The thing with CPES is that it doesn't build. Put it on, it seals, once it's cured, that's it! It's designed for porous materials, like more porous than just new plywood. Why do you think it's manufactured by a company called Rot Doctor? It's designed for weathered material (read dry rotted). Yes, I know...they will tell you it works great on new ply, but then they are selling the product, however, I've got no dog in the fight. Do what you want. I don't think you'll find a new mainstream wooden boat manufacturer that is using CPES as opposed to a regular epoxy, probably for a good reason.
Wanna build up some thickness to smooth out, it won't do it without a ton of coats. It's not as viscous as a regular epoxy. Epoxy will build much faster for a smooth coat if that's what your goal is. I'm always surprised at people that think they can just mop on more coats of something thin, then have questions why their paint doesn't lay down really smooth when it is all said and done.
There is no quick trip to making a great looking paint job and a well sealed durable tear. It takes time to level it all out and get rid of the grain and dimples in the ply. When someone asks, "Is 3 coats enough?"...well, you are the person there doing it...so how does it look? If it's going to be a painted tear, spray some primer on with a rattle can and look at the finish. Is it what you want, are you happy with it? If not, put on some more and sand and flatten it out. The quality of your paint job is only as good as the time and effort you put into the base coats. Paint won't hide poor prep work. Just spend the time and do it correctly, it's worth it in the end. All epoxies/ or polyesters need to be top coated and don't put them over an oil based stain. If you drag it around before you shoot paint on it, you run the chance that the surface can be contaminated and will not accept paint well. It will need to be cleaned with a solvent and scuffed, and more than likely, another coat prior to painting. I'm sure others may disagree with me on this. To each their own. Doug
