With the 12v refer, I was wanting some more battery capacity, but with a teardrop, you have limited space and weight carrying. This might be a good choice.
Smart Battery makes a 12v drop in replacement battery that is Lithium Ion. The electronics to protect it are on-board the battery. A 100ah Group 31 type battery is around $1300, but they are supposedly good for 3-5000 cycles, so over the long haul may be worth the price. The good thing is it's truly drop in with no changes needed for your charger or converter.
They are claiming you can draw these down 100%! After around 2000 cycles, the battery would be degraded by 20%. I suppose if you didn't go that deep, you'd have less degradation.
http://www.lithiumion-batteries.com/products/12v-100ah-lithium-ion-battery/
FEATURES
Fully automatic built in battery protection system
Automatic low voltage cut off - 8v
Automatic over voltage cut off - 16v12V 100AH Lithium Ion Battery
Automatic short circuit cut off - instant
Automatic internal cell balancing
High quality bolted cylindrical cell design
Built in cell safety fuse " Nano Cell Fuse Technology "
Long life 3000 - 5000 cycles
Lightweight - up to 70% lighter than lead
No voltage sag - faster cranking for motors and higher voltage for continuous consistent power.
Dry Battery - no toxic lead or acid
Zero Maintenance
No venting or gassing
Heavy duty stainless steel bolts, washers and flat washers included
99.1% efficient
Green ROHS compliant - No Lead
Use 100% of rated capacity
Does not heat up during use
Connect in series or in parallel
One battery for 12v, 24v, 36, or 48v applications
The Smart Battery SB100 12V 100AH Lithium Ion Battery is the perfect replacement from a group 31 AGM, GEL or Lead Acid Battery. The SB100 is designed as a "drop in replacement" meaning all you have to do is take out your old group 31 battery and place the SB100 in the same way.
