This is the first side wall I have built for my TD. The wall panel is sitting on the trailer frame but needs to be turned 180 degs. to face the other direction. The empty panel is now filled in with 3 horizontal struts. The door is of course to be cut out. The structure consists of 1/8" premium pine ply and the framework is 19 mm x 64 mm timber with 19 mm x 42 mm spaced in between the larger pieces.
I have bought some 1" thick "Polyurethane" sheet that I will cut to fit in each each panel. These pieces will be glued in and then these wall inserts will be trimmed using a hot wire. I have done this many a time making special section wings for high performance RC aircraft. I am now ready to finish off the wall but I need to make some big decisions. To glue a corresponding plywood skin onto the frame, I will need to buy about 60 clamps. This will cost big $'s. I also want to ensure that the entire surface is fully glued to the plywood skin. To do the gluing, I need some glue with a "long open pot time" and this will also cost heaps of $'s. I still have the problem of clamping and weighing the plywood down on the frame.
There is another way I can finish the side. I can apply a layer of 6 oz fiberglass woven cloth across the frame and seal it with Polyester resin. The glass would be laid on a 45 degree angle to the base of the frame and a second layer applied being laid 90 degrees to the first. This will give me the stiffest and strongest wall structure possible which is what I want. Laying the fiberglass is a piece of cake for me to do having built many glass boats, timber boats and repaired lots more. The cost of doing this is far cheaper (for me) that to sheath the wall in plywood as I don't have to spend a fortune on clamps and other tools. The cost of the clamps and tools is more expensive than glassing both wall panels. Glassing also achieves a complete bond to the framework and the Polyurethane. I also get a finished surface that is ready to paint. It is totally waterproof and super strong. The Polyester resin is also less than 1/3 the cost of epoxy resin and is much easier to mix in the proportions needed ie, hardener/resin.
What do you guys think of this form of construction, would you do this yourselves and do you think two layers of 6 ox glass be enough? It's been a long time since I built a boat in glass and would like your opinions.
The wall as shown in the photo will be lifted up another 3" and obviously, it will turned around 180 deg's. The glassed wall then becomes the exterior surface of the finished wall. Unfortunately, the pencil line of the curved outline can't be seen.
Kody
