Wiring diagram
Wiring diagram
Postby Yak » Mon Apr 20, 2015 7:01 pm
Will this work :lol:
Yak
Re: Wiring diagram
Postby DrCrash » Tue Apr 21, 2015 8:41 am
I have my " whizbang" on the other side of the "flux capaciter"!
DrCrash
Images: 51
Re: Wiring diagram
Postby ctstaas » Wed Apr 22, 2015 12:03 am
As long as the holy water doesn't dry up should be fine.
ctstaas
Re: Wiring diagram
Postby mustangcats » Wed Apr 22, 2015 7:15 am
Why don't you just plug it in and see what happens? :)
mustangcats
Images: 18
Re: Wiring diagram
Postby jstrubberg » Wed Apr 22, 2015 7:47 am
Just don't let the smoke out. They never work right after you do that.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Re: Wiring diagram
Postby Bigwoods » Wed Apr 22, 2015 1:25 pm
Looks like the one I used. The eel is kind of a nasty little beast.
Greg in Northern Minnesota
Bigwoods
Images: 104
Re: Wiring diagram
Postby Gladtobehere » Wed Apr 22, 2015 5:53 pm
Must be an older diagram! I don't see any Neds. Noise emiting diodes? They work great ........but only once.
Gladtobehere
Re: Wiring diagram
Postby Kaz » Wed Apr 22, 2015 8:01 pm
I have found that a cork from a bottle of good scotch works better than a bobber. :R
Kaz
Kaz
Images: 122
Re: Wiring diagram
Postby JuneBug » Fri Apr 24, 2015 7:43 am
Well there is a tear collector near the end, so should work fine for teardroppers.
I can understand how all the pieces of a tear drop go together from a nails, screws, wood perspective. When I think about wiring, though, in my mind it looks EXACTLY like that diagram.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Re: Wiring diagram
Postby RLG-GSG » Sat Apr 25, 2015 12:43 am
I think I found the problem, the squirrel should be in one of those go roundy things
George
RLG-GSG
Images: 5
