Glue a rubber roof
Glue a rubber roof
Postby southpennrailroad » Tue Jun 16, 2015 6:57 am
Can someone recommend a glue to cement a rubber roof to luan? Where might I get this from?
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Re: Glue a rubber roof
Postby mustangcats » Tue Jun 16, 2015 10:06 pm
Do you have EPDM rubber roofing? If so, I used Roofkit Latex Bonding Adhesive. I bought mine at Menard's...not sure if they have stores where you live. You could try Home Depot, Lowes or any other home improvement store. The instructions say you can either use the contact method or the one sided wet method. I chose the wet method (rolled the glue on the plywood) and then attached the rubber roof directly to the wet glue. I figured this method would let me make corrections in case the rubber roof needed to be repositioned as I was putting it down. The roof is 3 years old and has not come loose.
mustangcats
Images: 18
