I think I figured out my build
Postby friz » Sat Sep 12, 2015 6:33 pm
I will start with my design parameters. I need it to be light and reasonably aero efficient. My TV is a 14 Ford Focus with a 5sp. This is the class of car I enjoy driving the most, so for the life of my tear, I don't think that will change. I really like the look of the classic teardrop so the profile will be a Grumman. For economy and light weight I plan to build on an NT 5X8 trailer.
The floor will be 3/4 ply. The sides will be 1/8" birch with exposed 3/4 ply frame for the classic woody look. The roof 1/8 birch as well. I may insulate and double wall the roof so I can keep the wood exposed on the inside and resist condensation. The interior side walls I plan to cover with foam backed carpet for a little noise reduction and minimal R value.
I was debating on including a galley on this build but reading some posts where people regreted not doing one changed my mind. Galley for sure.
Finishing will be a few heathy coats of marine varnish and possibly some paint to match the TV in between the frame work on the sides. The bottom will get a treatment of roofing tar.
Some lights, roof fan, and a simple electrical system and I should be good to go.
Let me know what I am missing or if I am heading down the wrong path altogether. Thanks in advance.
Friz
The "Sin Bin"
150133
friz
Images: 6
Re: I think I figured out my build
Postby KennethW » Sun Sep 13, 2015 7:44 am
3/4 floor is over kill. 3/8 would be enough.One does not walk on the floor of a teardrop so no need for the 3/4.
How will you seal the edges of the 3/4 exposed plywood frame? Might be a problem area.
Be aware that marine varnish require biannual work if outside for longer periods of time.
Good luck.
KennethW
Images: 82
Postby friz » Sun Sep 13, 2015 9:31 am
Thanks! One of my last projects was a 24x48 shop so it will live inside when not in use. I was wondering about the edges of the ply. I was hopeful that enough varnish would keep it sealed. I'll scale back the floor as you suggested.
The "Sin Bin"
150133
friz
Images: 6
Postby GPW » Sun Sep 13, 2015 10:02 am
Friz, we’ve had great Luck with a mixture of 75% Mineral Spirits , and 25% Polyurethane varnish , slathered on in multiple coats till it won’t take any more , and it does a really good job sealing the end grains ... and is probably best used everywhere... ;)
Postby friz » Sun Sep 13, 2015 10:09 am
GPW wrote:Friz, we’ve had great Luck with a mixture of 75% Mineral Spirits , and 25% Polyurethane varnish , slathered on in multiple coats till it won’t take any more , and it does a really good job sealing the end grains ... and is probably best used everywhere... ;)
So would it be best to seal everything with this mix then follow up with the marine varnish to get the gloss?
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sun Sep 13, 2015 7:07 pm
Playing with sketchup.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Mon Sep 14, 2015 12:47 am
Playing some more. Alum skinned rook and corvette tail lights.
The "Sin Bin"
150133
friz
Images: 6
Postby GPW » Mon Sep 14, 2015 6:39 am
Those of us with trailers in rainy parts of the country must seal EVERYTHING ... One little leak can cause major rot/de-lamination problems on unsealed /unprotected wood parts ... Makes a good base for more Glossy varnish or paint .. 8)
Postby friz » Mon Sep 14, 2015 11:54 pm
I corrected the scale of my model and placed it on the model of the trailer I plan to use.
The "Sin Bin"
150133
friz
Images: 6
Postby noseoil » Tue Sep 15, 2015 7:29 am
Fritz, I like it! Looks like a nice clean package & even matches the paint! I'm a bit confused, it's going to be painted to match, yes? Not a traditional "woody" look with exposed wood trim, correct?
137905
noseoil
Images: 670
Postby friz » Tue Sep 15, 2015 9:23 am
I have yet to model the wood trim. Soon
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Tue Sep 15, 2015 9:28 am
I also need to refine some of the interior dimensions. I don't think my mattress will fit as it is now.
The "Sin Bin"
150133
friz
Images: 6
