12v Freezer or Fridge?
Postby Rainier70 » Thu Nov 19, 2015 1:31 pm
I am looking at the 12v fridge/freezer units such as the TruckFridge 41liter model or the more expensive ARB etc. I know most people probably use these as refrigerators only, but does anyone use them mainly as a freezer?
As a fridge or a freezer what is your experience on energy consumption? I currently have a 100 watt panel and a smaller 85 amp/hr battery.
Any idea on amp hours used in a day?
Rainier70
Images: 244
Re: 12v Freezer or Fridge?
Postby Rainier70 » Thu Nov 19, 2015 3:05 pm
Looks like ARB fridges use the same compressor as the TruckFridge or Indel B units.
Rainier70
Images: 244
Postby kirkman » Thu Nov 19, 2015 3:21 pm
I have one and it works great. I do however have a group 24 120 amp hour battery and a 100 way solar panel. That said you should be good for 3 or 4 days. :thumbsup:
kirkman
Images: 55
Postby Vedette » Thu Nov 19, 2015 4:16 pm
We have a Koolatron 12V fridge that we bought second hand and it works Great!
It is listed as keeping things cold up to 45 degrees below the outside ambient temperature.
Thus, when we camp in the early spring and late fall, we unplug it before we go to bed, or we find that it freezes things by morning.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby dales133 » Thu Nov 19, 2015 4:20 pm
Im getting a 40l engel for mine and they are a propper compreszor fridve.
They use hardly any power as they cycle on and off as required and unless your always openi g it they use something like tamps per hor
dales133
Postby MtnDon » Thu Nov 19, 2015 6:46 pm
A friend I travel the backcountry with has an ARB. Has had it for over a decade now. He uses it as a freezer. Freezes some food. mainly freezes jugs / bottles of water. We then cycle them from the freezer to our Extreme coolers where we keep most of the food and drink. Endless cycle. And we keep some ice cream in the freezer too.
MtnDon
Images: 24
Postby makevx73 » Thu Nov 19, 2015 8:24 pm
MtnDon wrote:A friend I travel the backcountry with has an ARB. Has had it for over a decade now. He uses it as a freezer. Freezes some food. mainly freezes jugs / bottles of water. We then cycle them from the freezer to our Extreme coolers where we keep most of the food and drink. Endless cycle. And we keep some ice cream in the freezer too.
Ya got me at the ice cream!!
Where do I get one? :applause:
EZ-Hauler 7x12, single axle, V front, sloped roof, all-aluminum, barn doors.
makevx73
Images: 5
Postby Rainier70 » Thu Nov 19, 2015 8:57 pm
MtnDon, ice cream is an indulgence that I could get used to! Refreezing cooler packs is also one of the uses I am looking at.
Kirkmam, what brand of fridge do you have? Do you know how much it runs your battery down or does the solar easily keep up with it? 100 watt panel is what I have too. Thanks
Rainier70
Images: 244
Postby S. Heisley » Thu Nov 19, 2015 9:10 pm
Postby Rainier70 » Thu Nov 19, 2015 9:21 pm
I hadn't heard of freeze dried ice cream before, and I thought it was a strange idea, but from the reviews on Amazon it sounds pretty good. Cool!
Rainier70
Images: 244
Postby Shadow Catcher » Thu Nov 19, 2015 10:55 pm
We have a Waeco and it is set so that things in the bottom stay frozen and things above are not, so the answer is yes.
Postby pete49 » Fri Nov 20, 2015 12:33 am
We too use a 41 litre Waeco mostly as a fridge and it does a good job as a freezer too. We normally leave it in the car while travelling so power draw isn't a problem. The best thing is you set it for a specific temperature and that's it ...set and forget it cycles as needed. :D so don't have to turn it off at night if its cold.
Pete
pete49
Postby kirkman » Fri Nov 20, 2015 2:12 pm
Rainier70 wrote:MtnDon, ice cream is an indulgence that I could get used to! Refreezing cooler packs is also one of the uses I am looking at.
I have two one in my egg camper......http://truckfridge.com/tf65.html
and this portable one that I use as a freezer in the egg and as a frig when using my tear.......http://truckfridge.com/tf41.html
The solar panel keeps the battery charged with out a problem that is as long as the sun is shining! :lol:
kirkman
Images: 55
Postby Jim.M » Wed Nov 25, 2015 7:25 pm
Waeco is also sold here in the USA by Dometic (with the brand name 'Dometic'). I've had one for 7 or 8 years and it is great. I usually run as a fridge but have also run it as a freezer.
When it's not going camping, it is keeping drinks cool in the house. one of the best high-dollar camping products I've ever bought. absolutely no buyer's remorse!
Jim.M
