Did I get myself into trouble?
Postby bosleybeebop » Tue Oct 25, 2016 12:58 pm
I poly'd my subfloor (anticipating having to set it on the rain before I was able to finish my build). Now that I have the walls/roof up I am wanting to put down either a hardwood/vinyl tile and I'm starting to think about adhesion. Ideally, I would use woodglue fastened on the studs for a hardwood floor. Knowing, glue first then poly...do I try and sand the poly finish off? I believe some of the new vinyl products use a sort of butyl/foam backer with adhesive.
Open to flooring suggesting and adhesives. I need to overcome some bolt heads as well that are not flush fit (had to leave them proud bcuz of ply/foam/ply sandwich)
bosleybeebop
Re: Did I get myself into trouble?
Postby friz » Wed Oct 26, 2016 3:24 pm
You could try a carriage bolt instead.
The "Sin Bin"
150133
friz
Images: 6
Postby booyah » Thu Oct 27, 2016 9:27 am
I would test out a peal and stick flooring solution... a lot of those are made to go over slick floors (existing linoleum etc). If you need to glue something, you can always sand off the poly, but it might suck... :?
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby booyah » Thu Oct 27, 2016 9:29 am
some of the peel and sticks look pretty nice, heres mine from my build and its holding up well so far (been over a year)
booyah
Postby Dale M. » Thu Oct 27, 2016 9:48 am
To replace bolt heads sticking up, you could try "elevator bolts"... Might even counter sink it a bit with "spade bit" if it compresses floor (foam) to much before becoming flush...
Might look at local sources first for the bolts...
Here is one source, but with internet access got to be 100 places to find what works best...
http://www.mutualscrew.com/Elevator-Bol ... 11955.html
To break the sheen of the poly and increase adhesion, scuff with sand paper, once it is a bit scuffed adhesion increases...
Dale
Dale M.
Images: 18
Postby bosleybeebop » Thu Oct 27, 2016 10:48 am
Great info! How do you tighten a carriage/elevator bolt when tightening into something a soft as 1/4" ply?
bosleybeebop
Postby tony.latham » Thu Oct 27, 2016 11:12 am
bosleybeebop wrote:Great info! How do you tighten a carriage/elevator bolt when tightening into something a soft as 1/4" ply?
Prong washers. I assume that you've got something else between your plywood and your frame like 3/4" of pine or something?
Try ACE hardware.
Tony :thumbsup:
Postby Esteban » Thu Oct 27, 2016 11:30 am
Steve - SLO, CA
Esteban
Images: 15
Postby Kharn » Fri Oct 28, 2016 7:47 pm
Try ACE hardware.
Tony :thumbsup:
Also known as "torque washers"
Kharn
Postby capnTelescope » Sun Oct 30, 2016 9:12 pm
I covered my floor with a coat of exterior gloss paint, and a wall to wall mattress. Bolt heads, shoddy paint job? No problem, it's all hidden.
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
