Window Question
Window Question
Postby TerryB89 » Sat Nov 23, 2019 4:27 pm
If I go to the junk yard and get a window out of a van, all it is, is a piece of glass in a rubber seal, how would you attach that to your tear build, and what if you mess up the rubber strip while removing it, how would you replace it?
TerryB89
Re: Window Question
Postby Modstock » Sat Nov 23, 2019 8:45 pm
Remember a van is just thin sheemetal. A teardrop is usually 1/2"to3/4" wood thick.
Probably wouldn't work.
Now if you find a trailer or camper getting parted out, those windows may work.
Sent from my H1611 using Tapatalk
Modstock
Re: Window Question
Postby GPW » Sun Nov 24, 2019 6:03 am
When you go there , look for Vans with “Interiors" , and windows that have a separate inner "trim ring" on the inside . For plywood trailers you can use most any window with a mounting flange.
Re: Window Question
Postby swoody126 » Sun Nov 24, 2019 7:37 am
check w/ your insurance agent to see if he/she can help you locate an RV salvage/wrecking facility
w/ all the flooding and stormage across the Nation recently there should be one close enough to visit for scrounging
sw
swoody126
Re: Window Question
Postby KTM_Guy » Mon Nov 25, 2019 5:06 pm
Remember most vehicle glass is not flat, most teardrop walls are. You might be making more work for yourself. To me a window that doesn’t open is useless in a teardrop. You need to be able to ventilate year round.
But like was said a RV salvage is a good place to look, we have a few around me and that all sell on eBay.
Todd
KTM_Guy
Images: 193
Re: Window Question
Postby mary and bob » Mon Nov 25, 2019 6:31 pm
For various window weatherstrip go to perfect fit.com. They have it with different width grooves. There is a lock strip that goes in after the glass is in place and requires a special tool. The one I use is made by Lisle tools, I think it is part # 47000. But like others have said you would probably be better off with a standard camper window of the type that uses a clamp ring. Use butyl tape under the outside flange and draw up screws evenly and re-tighten them after several hours.
mary and bob
