Final Report :
We got all the welding done on the car ( a good bit ) , went through a small roll and large roll of wire , and everything worked out fine until the very end , when we had an incident of the wire not feeding ???
After checking out a lot of videos on the subject , we found out the trigger was “sticky” and sometimes had to be pressed twice to operate . So not bad considering we made a gazillion spot welds on that thin sheet metal . As far as I’m concerned the welder paid for it self , so it's all good !
The welds weren’t pretty , but did the job !!!
And now , after all this welding practice , we have a new confidence to make some trailer mods on the next trailer build ! Knowing how to weld is really a game changer , opening many new possibilities . The HF machine just was a cheap way through the door .
And the little Car is coming along .
