Broken Galley Slam Latch
Postby Minics04 » Tue Jul 07, 2020 6:50 am
Has anyone had a T-Handle Slam Latch break? Allow me to explain:
I use two of these to secure my hatch. I always turn the handle to retract the latch(I don't slam them) to close. This weekend, I went to open the galley and one of the latches would not retract. After fighting with it, I did get the hatch open.
I found a metal piece that must have broken free internally stuck hanging out by the latch.(Pic enclosed)
2nd question: I only secure my galley hatch with two of these latches and I am now concerned with them failing and the hatch opening on the road. Is this just a one off or should I consider using another latching system??
Thanks for any help!!
John
Minics04
Re: Broken Galley Slam Latch-REPAIR!
Postby Minics04 » Tue Jul 07, 2020 9:13 am
Did a little work on the latch and it is repaired.
Offending Broken spot welds on piece
Drilled Out Spot welds
Inside
Minics04
Postby Minics04 » Tue Jul 07, 2020 9:15 am
Would only allow 3 attachments.
Minics04
Postby Minics04 » Tue Jul 07, 2020 9:17 am
Last Pics
Minics04
Postby tony.latham » Tue Jul 07, 2020 9:40 am
Grease is good!
Perhaps I should try to do the same to my door latches that are similar without having to disassemble them.
T
Postby Pmullen503 » Tue Jul 07, 2020 9:52 am
Nice repair.
Pmullen503
Images: 67
Postby Minics04 » Wed Jul 08, 2020 6:18 am
Thanks Guys! :D
Minics04
Postby Shadow Catcher » Thu Jul 09, 2020 5:40 pm
We had a problem with the slam latch working itself lose and the galley hatch opening. I installed a couple of Perko marine latches.
https://www.perko.com/catalog/category_products/locks_and_latches-flush_mount/
Postby Minics04 » Fri Jul 10, 2020 8:33 am
Good idea!
I had Perko latches om my boat. Never thought about using those!
Thanks!!! :thumbsup:
Minics04
