Pictures
Pictures
Postby ArtMini » Tue Sep 29, 2020 9:31 pm
I'm having trouble posting pictures. It says the pictures are to big. How do I make the smaller?
HAVE FUN STORMING THE CASTLE!!!!
ArtMini
Images: 16
Re: Pictures
Postby saltydawg » Tue Sep 29, 2020 10:04 pm
I use imgur, it works well. upload, click on edit set the size to around 1000-1200 for most people screen. Then click on share links and select forum, copy link paste in the post.
Scott
Lost in Maryland
saltydawg
Re: Pictures
Postby eLink » Tue Sep 29, 2020 10:07 pm
If you are using Windows, you can use the built-in "Paint" program. (you might be able to select the file, right-click and choose "Edit")
Choose "Resize" from the menu at the top, select the "Pixels" radio button, then enter the values 640 x 480 (or vice versa). Save and done.
eLink
Images: 142
Re: Pictures
Postby saltydawg » Tue Sep 29, 2020 10:13 pm
Scott
Lost in Maryland
saltydawg
Re: Pictures
Postby saltydawg » Tue Sep 29, 2020 10:17 pm
You need to be careful changing the pixel size. make sure the ratio stays correct or you can stretch or squish a picture.
Imgur keeps the size ration correct unless you force it to change it.
Scott
Lost in Maryland
saltydawg
Re: Pictures
Postby noseoil » Wed Sep 30, 2020 8:13 am
In Linux I open a picture I'm using, change the picture in the Gimp program (crop, contrast, etc.) then post into the gallery. From there, just copy into the thread for use.
163305
137905
noseoil
Images: 670
Re: Pictures
Postby twisted lines » Wed Sep 30, 2020 9:59 am
Microsoft Office Picture Manager (07) :thumbsup:
Racking up; And Rapin foam
twisted lines
Re: Pictures
Postby tony.latham » Wed Sep 30, 2020 10:14 am
I upload to Imgur at a resize of 640 x 480.
:pictures:
New Pictures ...... finally
Postby ArtMini » Wed Sep 30, 2020 10:57 am
Trailer right side small.JPG (271.24 KiB) Viewed 1300 times
ArtMini
Images: 16
Re: Pictures
Postby ArtMini » Wed Sep 30, 2020 11:08 am
Trailer right + front small.JPG (81.36 KiB) Viewed 1288 times
Trailer back small.jpg (107.22 KiB) Viewed 1288 times
ArtMini
Images: 16
Re: Pictures
Postby les45 » Sat Oct 03, 2020 11:11 am
I've used PIXresizer for years to reduce my pics for this forum and several others that I use. Free download and easy to use.
However, I do most of my work on a PC and not a smartphone.
les45
Images: 605
