Shadow Catcher wrote:We have Kedar Rail on three sides of the tear and four tarps with Kedar welting attached. One with netting. this gives lots of flexibility
saywhatthat wrote:https://www.youtube.com/watch?v=G2lcv6eP4t8
might take a look at a DIY 270 awning
ricky herbold wrote:I have a overland vehicle system 270° awning and it’s awesome. Easiest and quickest awning setup I’ve ever dealt with.
The awning also has walls that zip on to turn it into a big tent. It’s awesome!
I’m not sure of the height, but you are correct. I needed the awning to be a littl higher than just mounting it to the top of the trailer for 3 main reasons. 1 was I needed the awning to clear the galley door when it was open and 2 was headroom. Number 3 was the walls need the awning to be a certain height so they are not bunched up on the ground or worse they don’t make it to the ground. I didn’t like the look of the awning sticking up that high when it wasn’t opened up so I made pivoting mounts that let it hinge up for deployment or lay flat on the roof rack for travel ( and to fit into the garage)Sparksalot wrote:ricky herbold wrote:I have a overland vehicle system 270° awning and it’s awesome. Easiest and quickest awning setup I’ve ever dealt with.
How high up is that mounted? Almost looks like it pops up before you deploy it.
ricky herbold wrote:I’m not sure of the height, but you are correct. I needed the awning to be a littl higher than just mounting it to the top of the trailer for 3 main reasons. 1 was I needed the awning to clear the galley door when it was open and 2 was headroom. Number 3 was the walls need the awning to be a certain height so they are not bunched up on the ground or worse they don’t make it to the ground. I didn’t like the look of the awning sticking up that high when it wasn’t opened up so I made pivoting mounts that let it hinge up for deployment or lay flat on the roof rack for travel ( and to fit into the garage)Sparksalot wrote:ricky herbold wrote:I have a overland vehicle system 270° awning and it’s awesome. Easiest and quickest awning setup I’ve ever dealt with.
Users browsing this forum: Westy and 8 guests
