by Shadow Catcher » Tue Mar 01, 2011 10:32 am
Just got back from talking with Ryan at Lefty Origionals. I had suggested to him that that he go with a 5X10, I have pictures of the first rolling chassis.
The frame is powder coated steel with Dexter axles and the 5 x 10 will come standard with breaks. The floor and sides are three-quarter inch marine grade plywood triple polyurethane coated all CNC router shaped including screw holes. What this means is that in the future if you have a problem a release agent can be used on the glue and a side replaced easily. The plywood has an oak inner ply, so it isn't Birch. Also hickory and a couple of other types of wood are available. The bottom is under coated with a rubberized undercoating and the sides extend down over the frame. Available will be a sink with water pump, gas cook top, available water heater, available external shower. Hubs are available to handle off-road tires. LED lights are available, he is using a Progressive Dynamics power center. Radio inside and/or out are available as is a TV. Fantastic fan is standard. Battery is up front.
Colors and how you want the cabinetry set up, pretty much whatever you can come up with.
