by Dale M. » Sun Mar 06, 2011 10:36 pm
Fiberglass won't stick to anything, the resin that holds fiberglass will stick to the wood.....
Fiberglass can be a good solution, but understand the surface you are putting it on has to be prepped to decent shape and if you are not really good at application, it will take hours of sanding and grinding to get smooth finish, quite frankly there is more important thing to do with your time..... I would consider some prefinished "sheet" products and just glue it on before I would go the glass/mat & resin option...
And its messy.... You will have to mask off every surface on TD you do not want contaminated with drips and spills.... If you have never worked with resin and cloth this in not the "scale" of project you want to learn on....
Dale
