measurements ???
measurements ???
Postby Boanerges4 » Mon Apr 11, 2011 3:55 pm
My ??? Is 32 x 30 adequate for a porta potty? Is 24 x 30 adequate for shower? Thanks :thinking: :?
Boanerges4
Postby Yota Bill » Mon Apr 11, 2011 11:50 pm
slowcowboy wrote:Have no clue my teardrop has no need or the space for one of them fancy things!!!!!!!
SLow.
then why bother responding?
I would suggest picking out what port-o-potty you want to use, and get the dimensions of it, but dont forget room for yourself first (I checked out one camper that had what seemed to be an adequite sized space for the port-o-potty, but it was too narrow to fit my shoulders in comfortably...the 3 other people with me didnt have a problem)
for the shower, I would say a decent way to measure would be to put both arms straight forward, then bend your elbows in 90 degrees (make a box with your arms) and have someone measure that for you, then add a couple inches for comfort
Yota Bill
Postby bobhenry » Tue Apr 12, 2011 6:41 am
SLow.
Bill is right it is the occupant more so than the equipment.
As a big boy I have found more than a few restrooms that I just didn't fit in.
Some one else made a suggestion similar to Bill's. Lay your hands palm down high on your chest and just touch finger tips to finger tips. Them measure elbow to elbow this is the absolute minimum measurment.
Re: measurements ???
Postby StandUpGuy » Tue Apr 12, 2011 6:55 am
Boanerges4 wrote:My ??? Is 32 x 30 adequate for a porta potty? Is 24 x 30 adequate for shower? Thanks :thinking: :?
24"x32" is one of the standard sizes for a smaller shower toilet combo and you can find plenty of 24"x24" shower pans online.
StandUpGuy
Images: 52
Postby fromeo » Tue Apr 12, 2011 10:53 am
24 x 32 Shower:
At 5'10, 225lb 24x32 is not bad. Not super roomy but it gets the job done. Honestly the biggest pain is the shower curtain, every time you bump into it they want to stick to you. Flat pans this size are way more roomy than the step tub but I couldn't swing a flat pan in this build.
I've seen pans this size with a toilet included. I climbed in and tried to go through the motions. Way too tight for me with that in there too.
- Frank
fromeo
