My TD #1 & 2 the handles were perfect
My new ones have T6 on the keys and are garbage.
Number 3 TD I've had the locking mechanism go bad in one door in two sets of locks. The whole lock assembly came out on one lock. The pins that lock the door are 1/8" difference so one set is very sloppy so I glued in a spacer. The glue didn't hold so I had to move my stop to keep it engaged. I like my doors to shut with ease and just a click from the lock. The ones with small pins require you to slam the door, not a good thing.
Vintique website is on a perpetual "Under Construction" phase
I noticed CampInn is using them too wonder if they are having the same problems? Danny
