by DezPrado » Sat Oct 29, 2011 6:23 am
I converted one of these right hand opening doors to a left hand opener last summer. (the supplier only had right-handers in stock & sold me the second one cheaply because his stock wasn't moving). Anyway moving on.... there are drain holes in the bottom that need to be filled, and new ones created when the door is inverted. I also discovered the glass window, top I think, was not cut symmetrical & wouldn't fit properly so a new one was made. In addition the exterior seal strips were not able to be reused either, becuase of the corner cuts & sizing/lengths now being different . The change-over took a bit of work to acheive the desired result but it is acheivable with perseverance. I'm happy with mine & it don't leak!!
Remember though, you might get a door that is perfectly symetrical so your mod process will be marginally different. Good luck
