How toRegister and license in utah..
Postby Enderhay » Sun Oct 07, 2012 9:35 pm
I have a HF trailer that came with a vin. The teardrop is almost done and I'm not sure where to start. My calls to utah DMV have been less than helpfull. Any help would be great.
Cheers
Check out my build blog.
www.brentmakesshit.com
Enderhay
Re: How toRegister and license in utah..
Postby doug hodder » Sun Oct 07, 2012 10:04 pm
While I have no idea on what to do in Utah...here in Ca, typically...you take in all the receipts (give them a copy), frame, body etc...., show what you've done, and get in front of a person. Make sure you have the trailer sitting in the lot, and if they are really particular about transporting an unlicensed trailer, go in advance and get a temporary transportation permit if they require one. I've never had any luck with a phone call....you need to be in front of a person...much harder to blow you off. Since you already have a VIN, I can't imagine that it's going to be a real problem. Here...I scratch build frames and have no VIN....just take in the receipts and do it as a "special construction". Just what works here. You can always just register it as a HF utility trailer, but most of the insurance companies will want it titled in something other than utility if you want insurance. Either way...you need to be in front of someone to plead your case. Just my opinion. Doug
Postby suckerpunched » Mon Oct 08, 2012 1:44 am
any trailer that is 750lbs and under does not need to be registered in Utah,,,build it light,,,,
TC
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby Corwin C » Mon Oct 08, 2012 1:25 pm
I'm not sure exactly what you need, but here is a starting point.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby Enderhay » Mon Oct 08, 2012 1:44 pm
Thanks Guys!
Enderhay
Postby CarlLaFong » Mon Oct 08, 2012 3:46 pm
suckerpunched wrote:any trailer that is 750lbs and under does not need to be registered in Utah,,,build it light,,,,
TC
According to the link, that doesn't apply to travel or tent trailers
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby jandmz » Tue Oct 09, 2012 7:13 pm
Here in Ohio, I just took the MSO that came with the trailer (Manufacturer's Statement of Origin) to the deputy registrar, gave them $48 and walked out with a tag. I hadn't even started putting it together yet.
jandmz
