First Timer Tire Rotation
Postby Pinecone » Sat Jan 30, 2016 10:55 pm
So, I've heard that one should rotate your TD's tires every 10,000 miles. Since I got my TD in 2013, I think it's probably time.
I'm going to do it myself, having never rotated tires in my life. I'm a little nervous. Is this how it goes?
1) Remove spare.
2) Loosen bolts on one wheel.
3) Jack up that side of the trailer.
4) Remove wheel #1.
5) That spare that I removed, put it on the same spot where I took the wheel off in #4. Hand-tighten nuts.
6) Let the jack down then tighten the nuts with torque wrench.
7) Loosen nuts on the other wheel.
8. Jack up the other side of the trailer.
9) Remove wheel #2.
10) Place wheel #1 where wheel #2 went. Hand-tighten nuts.
11) Let the jack down then tighten the nuts with torque wrench.
12) Mount wheel #2 as the "spare".
13) Apply grease in that little valve thingy that sticks out of each end of the axle.
14) Pray that a wheel doesn't fall off!!
Any advice for this noob? Thanks in advance!
Greg
G. Pang, NW Tear Jerker
Check out Teardrop Event Videos I put together!
IRG 6.0 2016: https://www.youtube.com/results?search_query=IRG+6.0
TOW Promo 2017: https://www.youtube.com/watch?v=mpxgE7H3CrA&t=11s
Pinecone
Images: 28
Re: First Timer Tire Rotation
Postby Loren » Sun Jan 31, 2016 12:23 am
Greg:
I'd use a tread gauge, available at any Walmart or auto parts store- and measure the tread on all grooves both sides- if tread depth is the same all the way across and the outside edges aren't worn, I'd not bother switching tires- if it ain't broke....but yeah, lube is a good thing but read up un it first- you want enough, but not too much.
Loren
Loren
Postby halfdome, Danny » Sun Jan 31, 2016 12:59 pm
Greg, I don't know if you have steel belt radial tires or not.
From my understanding (not an expert at the least) steel belted radials should only be rotated in the same direction, IE front tires to rear, rear to front, not crossing over.
Something to do with wear patterns in the steel belts and possible failure.
Something you might want to look into before going through all that work.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Vedette » Sun Jan 31, 2016 1:58 pm
Yes, Greg
Old time cross rotation was for bias ply tires, and was done a lot back in the day.
But, like Danny said.........new "Radial tires should always be kept on the same side.
Only rotate front to back! :thinking:
Changing their rotation direction is not a great idea. You will get pre mature wear and possible failure. Also they will be noisy!
Good to see you here man. :thumbsup:
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby lrrowe » Sun Jan 31, 2016 4:09 pm
I always buy my tires from dealers who will rotate them for free (I know nothing is free as somewhere, everything has a cost"
I let them worry about what is the best method as long as I stay to the schedule. This is another reason I do not skimp when it comes to my tires. I really believe that the better deal may cost more.
Bob
lrrowe
Images: 439
Postby Pinecone » Sun Jan 31, 2016 8:56 pm
Front to rear? I'm talking about rotating the tires on my teardrop trailer, not on my car! You guys are confusing the noob! :D
I guess a place to start is to see what kind of tires they are. Why is everything always more complicated than I think they should be?! Well, I guess that's how we learn.
Greg
Pinecone
Images: 28
Postby lrrowe » Sun Jan 31, 2016 9:14 pm
Missed that important point. Sorry. Now seeing that you are only talking about your TD tires. I do not see myself ever rotating them.
Bob
lrrowe
Images: 439
Postby BrwBier » Sun Jan 31, 2016 10:03 pm
After being a mechanic for 35 years I can say the OLD rule was for radial tires to stay on the same side. That is not the case anymore. There will be a maintenance section in your owners manual (you know, that thing in the bottom of your glove box) that will show how to rotate your tires. Modern radials are just fine with switching sides. A general rule is to cross the non drive axle tires and the drive axle tires front to back. Example for a front drive car, rf to rr lf to lr lr to rf and rr to lf. Some cars maybe different but the owners manual will tell you that.
BrwBier
Images: 100
Postby MtnDon » Mon Feb 01, 2016 12:18 am
I have never, in 4 decades of owning trailers of all sorts and sizes, rotated a trailer tire. I have not noticed any uneven wear patterns. I do rotate the tires on the cars and trucks every 5000 miles or so using a suitable pattern in this link.
MtnDon
Images: 24
Postby MtnDon » Mon Feb 01, 2016 12:56 am
We rotate tires on a motor vehicle because those tires are subject to various loads that trailers do not experience, namely acceleration forces, braking forces and cornering forces, especially the front turning wheels/tires. The forces are concentrated on the front wheels of a front drive vehicles so rotating those with the rears can help even out the wear a lot. Or simply leave them alone and when the fronts get worn out put new ones on the rear and put the old, hardly worn rears on the front.
The wheels and tires on a typical single axle TD simply go along for the ride. IF the TD has brakes, then there may be braking forces. Unless the TD brakes are maladjusted and cause lockups there should be little if any effect on TD tire wear, IMO. Same thing for CT's as far as I am concerned.
A tandem or triple axle trailer that does a lot of turning, as happens more when used around town a lot, may benefit from rotations as tandems and triples can get a lot of tire scrub on tight turns.
MtnDon
Images: 24
Postby Socal Tom » Mon Feb 01, 2016 9:34 am
Vedette wrote:Yes, Greg
Brian & Sandi
This is no longer true. Modern radials can be rotated to neither side.
Socal Tom
Postby Socal Tom » Mon Feb 01, 2016 9:35 am
MtnDon wrote:I have never, in 4 decades of owning trailers of all sorts and sizes, rotated a trailer tire. I have not noticed any uneven wear patterns. I do rotate the tires on the cars and trucks every 5000 miles or so using a suitable pattern in this link.
Me either.
Socal Tom
Postby rockinrobin » Mon Feb 01, 2016 1:44 pm
Me three!! My 2008 Pleasant Valley still has the original tires. They are going to die of old age before wear. Of course I only put about 4000 miles per year on it. Ronnie :thumbsup:
" It's all good"
rockinrobin
Titanium Donating Member
Images: 56
Postby booyah » Mon Feb 01, 2016 2:08 pm
Brian & Sandi
Unless the tread pattern is directional (like on most of my cars)
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby Socal Tom » Mon Feb 01, 2016 3:58 pm
booyah wrote:]
That is true whether its radial or bias ply.
Socal Tom
