Boats for sale
Tom&Shelly wrote:As for the half inch or so of glass insulation between the legs of the wooden chair and the thinly covered metal floor, when the lightning bolt travels several thousand feet through ionized air, what's to prevent it from ionizing that last few inches of air around the glass?
I’m sure those old stools are a holdover from the early lookoutbdosborn wrote:Tom&Shelly wrote:As for the half inch or so of glass insulation between the legs of the wooden chair and the thinly covered metal floor, when the lightning bolt travels several thousand feet through ionized air, what's to prevent it from ionizing that last few inches of air around the glass?
Bingo!
I saw one of these when I was a kid visiting a lookout station, it wasn't till many years later that I understood why it wouldn't work. Air is a very good insulator and the lighting has already traveled miles through air to get to you; the glass insulators don't do a thing. The idea behind lighting protection is to have everything inside of the building rise and fall at the same potential as the lighting is conducted to ground around you.
tony.latham wrote:twisted lines wrote:Broke a femur
Seriously???![]()
lfhoward wrote: I physically had to remove the SD cards & use them to make a disk images on my desktop computer. Now I can re-image new ones if needed.
cjlangellier wrote:I had an interesting day today. My wife had a coworker ask us to go through her father’s estate
cjlangellier wrote:a 1955 Delta drill press, a 70’s era Atlas metal lathe,
cjlangellier wrote:I had an interesting day today. My wife had a coworker ask us to go through her father’s estate to see if we would be interested in any of his tools. He was a machinist for International Harvester. We ended up bringing home a 1969 Cub Cadet lawn tractor with a wagon and snow blade. He was the original owner in 1969. He clearly took exceptional care of the tractor and it was too cool of a story for us to pass up. In addition to the tractor we brought home a 1944 Delta Bandsaw, a 1955 Delta drill press, a 70’s era Atlas metal lathe, a bench grinder and cheap router table.
Capebuild wrote:Great score on the tools, Cody.... especially the drill press and lathe.
Tom&Shelly wrote:I'm almost jealous. Glad they went to a good home!
cjlangellier wrote:I'm planning to do a cleanup/restore on the tractor and implements and the band saw. I haven't decided if I'll keep the lathe yet. My garage is small and it takes up a good amount of room. Not sure I'd get enough use out of it to justify it sitting around.
bdosborn wrote:lfhoward wrote: I physically had to remove the SD cards & use them to make a disk images on my desktop computer. Now I can re-image new ones if needed.
Hmm, good idea. I've already had one go bad...
