Building the Generic ET
Postby Hinermad » Sun Jun 01, 2008 9:08 am
mikeschn wrote:I believe I have the RV-3095.
http://www.winegard.com/mobile/sensar.htm
Will that still work?
Mike,
Sorry to drag up an old topic, but I wasn't here when it was new.
Whatever antenna you use now for analog TV will still work for digital TV. The antenna doesn't care. A coat hanger will still work, if you can figure out how to attach it to the set.
What needs to change is the TV itself. An analog-only TV will need a converter box; a digital TV won't because it'll decode both analog and digital broadcasts.
Dave, taking all the fun out of technology
Behind every successful man is a woman who wants a teardrop camper.
Hinermad
Images: 5
Postby mikeschn » Sun Jun 01, 2008 9:59 am
Dave,
Cool! Thanks for that tidbit!
Postby mikeschn » Sun Jun 01, 2008 6:01 pm
A little more progress on the roof today... and now we are out of 1/8" plywood. :cry: And we still have the other side of the roof to do...
Here on page 8 of my ET album are the other photos I took today. :D
http://www.mikenchell.com/Generic_ET_Ph ... ndex8.html
Postby cuyeda » Mon Jun 02, 2008 1:37 am
Mike,
Lookin' good! It is nice to see a well thought out plan come together quickly (when the weather permits). Your album is great, and I am sure taking so many pictures may have slowed you down a bit. I have a couple questions.
1. What type of fasteners did you put the floor framing together with? Screws or nail gun? I looked but did not see any screw heads.
2. What type of insulation did you use? Is it the bubble foil wrap stuff, or foil layered foam core?
Thanks in advance.
Cliff & Vanessa
cuyeda
Postby mikeschn » Mon Jun 02, 2008 3:27 am
I put the floor together with drywall screws.
The insulation is foil lined foam core. It bends pretty easily!
Postby Dark Horse » Mon Jun 02, 2008 9:17 pm
Thank you for the update, Its looking great.
I'm gonna borrow a few ideas of yours if you don't mind.
Jim
I like anything that turns money into noise.
Dark Horse
Postby mikeschn » Tue Jun 03, 2008 3:21 am
Go for it. Be sure to take pictures, and let us see what you borrowed! :D
Jim
Postby jagular7 » Tue Jun 03, 2008 9:23 am
Mike, you screw in wood planks to help secure the outer layer shell. You only glue the outer layer shell to the framing? Or you also screw? If you you do both, then why use the extra pressure from the wood planks? How do you fill the holes after removing the wood planks and to keep a 'spotless' outer surface?
Mike
Jagular
Lenexa, KS
jagular7
Postby mikeschn » Tue Jun 03, 2008 6:10 pm
Hi Mike,
I was waiting for someone to ask about that.
Originally I was going to strap the outer shell to the spars, but I didn't have enough straps. So rather than going shopping, I figured I'd try the wood planks. I had mixed results. The plywood is stuck to the spars nicely, but it's not stuck to the sidewall very well. I ended up going back and adding another layer of glue to the sidewalls, and putting a strap on that anyway. That pulled it in nicely everywhere except for the front where it is almost flat. So a couple flat tip screwdrivers helped that.
The next step is to coat it with CPES, and then fill the holes with Epoxy filler. That should keep it watertight. Naturally if I was building a woodie, I would have used straps or sandbags, or both.
I found using the planks somewhat difficult because the spars were not in a straight line all the way across the trailer in most spots. Of course I don't know which would have been easier, straps or planks.
Postby prohandyman » Tue Jun 03, 2008 6:20 pm
Mike
What will the outside surface be?
Dan
prohandyman
Images: 785
Postby mikeschn » Tue Jun 03, 2008 6:26 pm
Dan,
Either painted with auto body paint or rolled with the Rot Doctor's Uniflex 255. I'm leaning in the direction of the Uniflex since I still have 2 gallons of the stuff downstairs. And it goes on easy, and hides all kinds of flaws.
I did the same on the Baja Benroy, as you can see on this page
http://www.mikenchell.com/Baja_Benroy_P ... ndex7.html
Postby LindaH » Wed Jun 04, 2008 5:41 pm
Okay Mike, it has taken me almost a week to read this whole thread of your build and it is awesome! :) :thumbsup: :applause: :worship:
When I end up helping David (hinermad) when I can because of Lake Ontario getting in the way, I just hope not to slow him down. :?
But we are definitely glad we joined this forum - it is great!!
- Linda
LindaH
Postby mikeschn » Wed Jun 04, 2008 6:08 pm
A week??? How long is it going to take you to read the other 300,000+ messages? :R :lol: :lol: :lol:
LindaH wrote:Okay Mike, it has taken me almost a week to read this whole thread of your build and it is awesome!
Postby LindaH » Wed Jun 04, 2008 7:17 pm
mikeschn wrote:A week??? How long is it going to take you to read the other 300,000+ messages? :R :lol: :lol: :lol:
Mike,
Good point! But hopefully by reading each and every detail I won't miss anything that I can tip off to David, which will actually assist in our build.
(That's my excuse and I'm sticking to it!) 8)
- Linda
LindaH
Postby mikeschn » Fri Jul 11, 2008 3:22 pm
Well, we got some more 1/8" plywood. So I guess we'll be playing on the ET this weekend. Stay tuned for some progress photos! :o
