S. Heisley wrote:Thanks to all who have contributed! To date, we have 117 trailers listed. If I missed or messed anything, please let me know.![]()
working on it wrote:S. Heisley wrote:Thanks to all who have contributed! To date, we have 117 trailers listed. If I missed or messed anything, please let me know.![]()
Sharon- you updated my trailer' weight to 1438lbs, a while back. After new tonguebox, lighting, extended run fuel tank & generator reconfiguration, complete axle makeover (3500Lb axle-brakes-frame reinforcements-suspension snubbers) were all added in, 1775lbs is my new estimated weight. I promise to stop before it reaches 2000lbs.
angib wrote:Congratulations to Sharon on such a wonderful job! I've taken her data and plotted it on a graph for those, like me, that 'see' data better that way.
This enables the data to be turned around to answer the question "what does a typical teardrop weigh?" and I've started a separate thread for that:
Estimating your teardrop weight
angib wrote:
...This enables the data to be turned around to answer the question "what does a typical teardrop weigh?" and I've started a separate thread for that:
bdosborn wrote:One of my goals with the Boxcar was to store everything in the trailer, nothing goes in the truck. When I weighed mine, I had it full of water (26 gal), food and all the camping appurtenances I see people put in their cars - lawn chairs, dutch ovens, awnings, etc. I wonder how much the trailer weight would go up for the typical teardrop if all the camping stuff in the car was included in the trailer.![]()
Section 26303. Every trailer coach and every camp trailer having a gross weight* (Not Gross Vehicle Weight Rating) of 1,500 pounds or more, but exclusive of passengers, shall be equipped with brakes on at least two wheels which are adequate, supplemental to the brakes on the towing vehicle, to enable the combination of vehicles to comply with the stopping distance requirements of Section 26454.
*Gross weight is the weight of the trailer empty.
*Gross Vehicle Weight Rating (GVWR) is the combination of the trailer and the load it is caring.
And don’t forget this:
Section 29003. (a) Every hitch or coupling device used as a means of attaching the towed and towing vehicles shall be properly and securely mounted and be structurally adequate for the weight drawn. The mounting of the hitch or coupling device on the towing and towed vehicle shall include sufficient reinforcement or bracing of the frame to provide sufficient strength and rigidity to prevent undue distortion of the frame.
(b) The drawbar, tongue, or other connection between the towing and towed vehicles shall be securely attached and structurally adequate for the weight drawn.
pchast wrote:Hi,
Weighed my 4 x 8 foamy and its too heavy....![]()
It came in at 560 lbs. I'm disappointed but it'll work
out well for us. Its hard to believe that paint weighs
so much.
Maybe it will get lighter as it cures?
Thanks,
