by eamarquardt » Wed Mar 23, 2011 3:07 am
Simply put, what you do depends upon your "terrain and situation". I'm at 800 ft above sea level and 20 miles from the ocean. No tsunami is gonna get me!
The wx here is MILD! I can (and do routinely) live w/o heat or air conditioning year round with no problem at all and am quite comfortable (although Suzy demands I turn on the heat occasionally).
The risks here in Southern California are fires and earthquakes. For some, dumb enough to build where they shouldn't, we also have occasional floods/mudslides. No stockpile of goods is going to be of any use if your house is burned to the ground,completely flattened in an earthquate, or washed away in a flood/tsunami. Plan "a" for a fire is "abandon ship" and "get outta Dodge". Any fire that gets my home will get a lot of others first and the fire departmenst will be overwhelmed. Credit cards and cash in the bank will be all that is required.
Having been through two big earthquakes (1971 and 1994) here, it is my experience that earthquakes are "localized". Just 20 miles away from the epicenter, things have been quite "normal" after the dust settles a bit. If worse comes to worse, I have a "dirt bike" that will go just about anywhere.
I'm not in an area that can flood, so I'm home free on that count.
So, my neighbors have swimming pools with lottsa water, I have a few 5 gallon propane tanks, some camping gear, a couple of small generators, and food in the cupboards. Good enough for me. If worse comes to worse, I'll leave town.
However, if I lived where the "weather can kill you", travel is impossible (roads blocked by snow), no water available, etc, I'd probably have a different plan.
What can we learn from Japan? If you house is leveled, washed away, or burned up, you're SOL and no amount of planning will alleviate your situation or potential suffering. A "cash reserve" in the bank could be your "ticket" to relief as in getting away to family elsewhere or some other accomdations. In a major disaster, it's gonna be tough and you're gonna be in "deep bandini" just like a whole lot of other people. That's just the way it's gonna be in an urban environment. As I recall during Katrina, the roads "outta Dodge" were pretty congested. If you're that worried, move now, or buy a second residence far enough away as to minimize the risk of both being rendered uninhabitable by a single event! Having the resources available and a plan to get away or send your family away as necessary, might be the best alternative.
Why fret and worry.
Gus
