Mitch/Pete
Thanks and yes I think I will eventually get a digital thermostat. I already see that the thermometer is twisted so I can't see the temp on the supplied thermostat. But this morning (I just got up at 02:30) and inside temp is 55/32 out. I guess you saw that the total I calculated yesterday as being 30. min per hour that the furnace was on.
The first night I did shut it down and awoke very cold but reached over and turned it on. This second night I had it set for about 55 as it is now all night running. I got to keep thinking that on the subject of propane usage that I should come out the same as using the blue flame as I would just leave that on for an hour or more straight at times because I just didn't want to get out of bed. But this furnace is only using about a total of 1/2 hour of propane. I calculate I will get eight days. I turned it on, attached to a new 20 lb tank on Monday at about 4:00 pm. Of course the temps are climbing this weekend.
Start up time is only 15 sec. Not worth calculating.
1st cycle Kick on time: 3:17, Kick off time: 3:30. Total on is 13 min. this cycle
2nd cycle Kick on time: 4:12, Kick off time: 4:25 Total on is 13 min. this cycle.
3rd cycle Kick on time: 5:05, Kick off time: 5:20 Total on is 15 min. this cycle.
4th cycle Kick on time: 6:00, Kick off time: 6:15 Total on is 15 min. this cycle.
Turns on @ 60 degrees/Shuts off @ 68 degrees
I feel comfortable that I can keep the furnace on and set at this pace/temperature so that I won't be real cold when I get up and still have heat/propane savings w/o shutting the furnace completely off while I sleep. That said I have the Atwood thermostat set at the seventh mark up from the left located at the bottom of the stat. Of course I will study this at different temps So my usage this night is that @ 32 degrees outside the furnace is cycling on/off once in less then one hour.
Trust me I am not just sitting here waiting for off and on of the furnace, I have been reading the following Tumbleweed_Tex articles.
http://tnttt.com/viewto ... 952#699952
These are great.
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
