Looking through Andrew's design library, I would like to build the Roswell--a trailer that would get looks anywhere it went and yet be easy to pull with my Subaru. The outside would be painted in one of those seventies retro metal flake colors. The windows (round naturally) would be reflective, with decals that look like people sitting inside, but are actually pictures of aliens. What else! This trailer is called the Roswell.
To build the body, I would start with one-eighth inch plywood, then fiberglass inside and out, with ribs fiberglassed in for support. Next, the openings would be cut out and an inside lip added to make a place to add a seal. The entry door would open up (like gull wing doors), held up by struts. The hatch would open too. I am leaning towards two doors that hinge on the sides.
Moving inside, the K.I.S.S.1 principle would be the order of the day. Between the ribs some sprayed on insulation. A couple of shelves and a storage cabinet. Everything painted white to keep it easy to light and clean. The galley would be similar to the inside, two shelves. One shelf for the stove and used as a counter top. The other for the ice chest and storage.
For special effects, a small smoke machine and neon lights underneath the trailer might be fun.
The carport is where I will build this, the garage is full of storage. Not the ideal location, but it works until it gets cold.
The time line is to use the spring, summer, fall to build (When the snow flies I hide inside, if only I could win the lottery and spend my winters in the tropics. ;-)
del
edit 27 jan
When I first researched teardrop trailers I found a web ring that had Andrews (a link to) drawings. I looked at the drawings and was excited about the roswell. Only then did I make my way into this forum. So I have seen Andrews drawings in the design library (thank you Andrew, a lot of work went into these). I have also found mention of the roswell on this cite. (trailer number four)
http://www.teardrops.net/mystery/index.html
A link to what i found so far.
http://www.tnttt.com/viewtopic.php?t=13571
Thanks to everyone who added great info to this thread.
del
