Nobody wrote:I bought one of the 11# tanks at Gander Mountain for around $40. Wal Mart sporting goods usually carries the 'post', hose w/fittings, & the POL adapter so the hose fits your tank. Madjack can tell ya how well it worked with the propane lantern at LCG last fall
kayakrguy wrote:One double check....Reading Dales note about the adapters, it sounds like you keep the 1# connector and just put a hose with a female adapter on it to connect to the tank? Do I have that right?
Ciao,
Jim
SmokeyBob wrote:I believe this is what Dale is talking about. The large end of this hose connects to your propane tank. The small end connects to your stove where the small disposable bottle would have gone. This is a 5' hose. I use one like it on my stove.
Dale M. wrote:kayakrguy wrote:One double check....Reading Dales note about the adapters, it sounds like you keep the 1# connector and just put a hose with a female adapter on it to connect to the tank? Do I have that right?
Ciao,
Jim
In most cases that is exactly what you do, and its the simplest way ... Seems that each manufacturer has propriety connector for hose at appliance and is next to impossible to find LONG hose with propriety connector.... The #1 disposable cylinder connector in most cases is the "common connector" that everything seems to mate to.
Dale
.also...that 1#connector is also a "self-regulating valve"...without it, you would need a pressure regulator at the tank........
Dale M. wrote:.also...that 1#connector is also a "self-regulating valve"...without it, you would need a pressure regulator at the tank........
Not quite what it sounds like ..... There is NO PRESSURE Regulation... Appliance operates at "tank pressure" and that is dependent on ambient temperature of air around tank....
Usually there is some sort of orifice that restricts the volume of gas flow to appliance but that is usually in control valve assembly of appliance.
Keep in mind we are discussing only appliances that operate of disposable #1 cylinders here....
Other types of appliances are low pressure devices that require a additional regulator to bring tank pressure down to appliances pressure, usually about 1/3 to 1/2 psi (about 7 to 10 inches water). The are more similar to home appliances like the cast iron stoves (nostalgia style) that are so popular....
Dale
madjack wrote:Dale M. wrote:.also...that 1#connector is also a "self-regulating valve"...without it, you would need a pressure regulator at the tank........
Dale
...if you say so but that has not been my understanding or experience....................................
