Small Heater Question
Postby Classic Finn » Thu Sep 06, 2007 8:00 am
48Rob wrote:Dear Heikki,
Suvi will produce more useable warmth that that little heater... :D
I tried that route last fall.
I hooked up a 12 Volt outlet to a 12 amp hour battery, from a scooter, to save space and weight.
It kicks out a little heat for about 20 minutes, then the battery dies.
I took 5 of these batteries with me, and still didn't have enough juice to stay warm for more than a day.
Honestly, I think a candle would put out more heat...
The heater could not keep up in 38 degree temperatures.
Finally gave up and installed a small RV furnace.
I'm happy now!
Rob
<img src="http://img.photobucket.com/albums/v284/1948rob/small%20pictures/heater1.jpg?t=1189080469">
Hi Rob
Well that idea is totally out then.. ;)
What does that furnace look like and is it possible to install somthing like that in our small tear?
Smaller than your great looking tear ... ;)
Best regards
Heikki
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Kens » Thu Sep 06, 2007 8:27 am
We get electric campsites when it is very cold. We have an electric blanket. It's very easy to wire for house current.
Good day every day!
Kens
Images: 26
Postby jeepr » Thu Sep 06, 2007 9:03 am
Best regards
Heikki
The problem I ran across is that I couldn't find a small furnace. I was looking for a gravity feed propane heater in a small BTU range. The only thing I found was furnaces with forced air. Atwood has a nice one. http://www.atwoodmobile.com/Products/furnace/7900.cfm The smallest is 12,000 BTU.
I don't think a teardrop would need more than a couple thousand BTU heater. Just a stansing pilot used to keep my Sunline warm with outside temps just above freezing.
If you come across something, let us know. I like those small catalytic heaters, but without drawing fresh air, there will be a moisture problem.
Mike C.
jeepr
Images: 38
Postby brian_bp » Thu Sep 06, 2007 10:50 am
Jst83 wrote:...If it will help warm the inside of a vehicle it should surely warm the inside of a teardrop. It doesn't take much, the wife and I had a little electric job and had to turn it off it got to hot. ..
That's the problem... the 12V heaters don't help much in a car. Some people do use similar 120V AC heaters, but I assume they have much more output.
We found a small electric heater quite effective in a 17-foot travel trailer, and obviously a teardrop could use a smaller one... but the 12V heater shown has only one tenth of the heat output of our 120V heater, which isn't much for the rate it flattens the battery.
brian_bp
Images: 9
Postby brian_bp » Thu Sep 06, 2007 10:54 am
jeepr wrote:The problem I ran across is that I couldn't find a small furnace. I was looking for a gravity feed propane heater in a small BTU range.
Some of the early moulded fiberglass travel trailers (e.g. Boler) had "gravity" furnaces, and some of their owners have become great fans of them. Unfortunately, it appears that they are no longer made. You might find a used one which works.
Those "gravity" furnaces are bulky, which might be a consideration in a teardrop, even in a low-output size.
brian_bp
Images: 9
Postby 48Rob » Thu Sep 06, 2007 6:24 pm
Heikki,
In the standard teardrop configuration, there isn't a practical place to install a furnace.
So... thinking outside the box (pun intended :D ) Since you are in the land of no air conditioner needed, a small furnace could be easily mounted in the tongue box.
Instead of cutting a huge hole and dealing with return air issues, simply vent part of the warm air into the night (under the trailer would make the most sense) and capture the rest in a 3" duct that could run under the trailer, and come through the bulkhead in a nice adjustable vent.
The vent could blow out above your feet/legs, and would be dissipated by the time it got to your head.
You could run the system with a standard thermostat, so the temperature would be more or less constant.
The furnace won't care, or consider where it is located, when the thermostat says it is warm enough, it will turn it off.
There would be a fair amount of wasted heat, since some would have to be directed to the outdoors, but 12000BTU is the smallest (new)available unit I'm aware of.
The loss wouldn't amount to much though, I don't believe, as the interior would warm quickly, and with the insulation you're installing, should stay warm for a time.
The unit I installed was about 10"x10"x22", others may be slightly smaller.
Now, all this said, if you camp where there is mains power, a basic electric heater will do the job.
Rob
48Rob
Postby goldcoop » Thu Sep 06, 2007 6:33 pm
Heikki-
Here is a propane heater that is placed outside, but the hose pump hot air into the TD.
It would require a inlet...
http://www.zodi.com/web-content/Consume ... tvent.html
The only real drawback is that the output is controlled by the propane burner which is OUTSIDE.
Coop
goldcoop
Images: 32
Postby Classic Finn » Thu Sep 06, 2007 6:42 pm
48Rob wrote:Heikki,
Rob
Rob that is interesting ;) :thumbsup: .. :thinking:
Classic Finn
Classic Finn
Images: 146
Postby Classic Finn » Thu Sep 06, 2007 6:48 pm
goldcoop wrote:Heikki-
Coop
Hi Coop ... I think Ive seen somthing similar here to that... :thumbsup:
Classic Finn
Classic Finn
Images: 146
Postby Classic Finn » Thu Sep 06, 2007 6:56 pm
Here is one that a local Caravan Dealer sells.. by Trumatic. They said yesterday (our time) that its very compact and would be easy to install .
Trumatic S 3002, 12 V. / 230v. 3 - 12 W, which comes with a control panel
and here is a small size front panel for it..
Classic Finn ;)
Classic Finn
Images: 146
Postby Classic Finn » Fri Sep 07, 2007 1:45 pm
Is the above name or model available in the Good Ol USA?
Classic Finn :thinking:
Classic Finn
Images: 146
Postby jeepr » Fri Sep 07, 2007 8:19 pm
I have been researching heaters. There are some super nice ones out there. They are marketed toward marine and truck bunks. The biggest problem I have found is price! It would cost as much for a tiny 7000 BTU bunk heater as it did to build my tear! :shock:
Here is one http://www.espar.com/html/products/technology_air.html
Anyone ever try something like this?
http://www.heatstick.com/
Mike C.
jeepr
Images: 38
Postby brian_bp » Sat Sep 08, 2007 7:54 pm
jeepr wrote:I have been researching heaters. There are some super nice ones out there. They are marketed toward marine and truck bunks. The biggest problem I have found is price! It would cost as much for a tiny 7000 BTU bunk heater as it did to build my tear!
Nice looking units. If you want to heat with diesel or gasoline (which might make sense for some situations, depending on the vehicle fuel, and fuel used for cooking), this seems like it would be a good solution. It's interesting how much less efficient the "petrol" version is (only available in the Airtronic 5; the smallest size of that range has almost twice the fuel flow - in mass rate terms - for the same heat).
For a cheap alternative, you could try to find an old VW Beetle (real, not "New Beetle") gasoline-fueled interior heater. I have no idea of the heat output rate, or if they were any good, but they certainly were made.
jeepr wrote:Anyone ever try something like this? http://www.heatstick.com/
Not me... and you won't find me trying to heat with a candle - or leaving one burning while I sleep - any time soon. I'm even less likely to pay someone US$30 for a device based on a stack of small clay flower pots, a nut and bolt, and some washers.
It is an interesting idea, and a more developed version of a bad idea I have heard of before: heating a trailer with a cookstove burner.
brian_bp
Images: 9
Postby jeepr » Sat Sep 08, 2007 8:33 pm
I was thinking more along the lines of building one... :D
TD are small enough, you may be able to use something like that as a pre-heater and shut it off when you climb in. It should keep warm with the body heat..
Mike C.
jeepr
Images: 38
Postby mikeschn » Sun Sep 09, 2007 12:32 am
Q managed to find some space to install one.
And don't forget, you can always use a ceramic heater if you are camping with electric!
48Rob wrote:Heikki,
Rob
Users browsing this forum: Bing [Bot] and 8 guests
