PICS ARE EASY
1. go to
http://www.teardrops.us/
2. Sign up
3. Go to the upload page and list the pics on your computer you want to upload. ONLY JPG or JPEG
3. Hit the upload button.
4. After they finish uploading you will go to the "your files" section and see them listed.
5. You then click on upload and it takes you back to the upload page where you first listed your lpics. This time around you click the box that under the part that says 'do this after files are uploaded' (make an x in this box) Make vBB post with [IMG] tags.
Now go back to your "files" section. and all your pics areuploaded and ready to be seen here.
When you are desiring to post them here, you start writing your post and when you want to insert a photo:
1 you click on the button on the toolbar below where you put in the subject of your post. that button is marked "Img*"
2 then you go to teardrops.us to the files section and right click on the photo you want to post. whenmyou right click you will see a selction called"copy link location" select that option .
3. Go back to your draft post and paste that location right after the "[img]" mark that was previously place there when you had hit the button.
4. Then hit the blue "close tags" underneath the toolbar.
Voila, you have posted a pic.
Repeat depending on how many pics you want in the same post.
