![Laughing :lol:](./images/smilies/econ_laugh.gif)
Somebody out there might know where you could get a valve that would allow only vapor out of those tanks. I assume their siphon tube is engineered longer to remain "under water" all the time, just like in the NOS tanks we use.
TinKicker wrote:Somebody out there might know where you could get a valve that would allow only vapor out of those tanks. I assume their siphon tube is engineered longer to remain "under water" all the time, just like in the NOS tanks we use.
brian_bp wrote:BPFox wrote:Here's how I tell, when the flame goes out, time to change the tank.
But seriously, losing the ability to cook and heat in the middle of a trip is not fun. I assume that my travel trailer has two tanks only so the second one can be used as reserve, not because people commonly use 40 lb of propane in one trip.
TinKicker wrote:You are definately right--the forklift will NOT run off vapor! Tried it. And you sho ain't gonna push dat baby out of a crowded parking lot with a pallet of stock in the air!![]()
BPFox wrote:...
Your forklift tank will have a positioning hole and your tank bracket will have a positioning pin. Make sure the pin goes in the hole and you are all set. If you don't do that you could run out of gas with plenty of gas still in the tank.
brian_bp wrote:BPFox wrote:...
Although I have never changed the tank on a forklift, I heard this is how they ensure that the cylinder is used with the right side up. This is important not only to keep the liquid outlet in the liquid, but to keep the pressure relief valve in the vapour and the gauge working (assuming that it works when horizontal).
Lgboro wrote:I just picked up a composite tank and can see how much propane is left in the tank.
wlooper89 wrote:Our tall skinny 11 lb. tank makes a tinkling sound when shaken or if it is riding inside the car. Does that mean there is a float and that the tank could accept a quantity gage? There is not a gage on it now...
